Annu Kumar
I don't if this helps: Use top quality Mobil 1 Synthetic
I got it from a line forman at my dealership. I don't know how to post it from my E-mail.2ndchance said:thanks, were did u get that notice?
2ndchance said:I am gonna have to do it the hard way and hit different dealers. If they all say the same thing then i will look for a tech who has some experience with these motors. Maybe gary at x-metal or sean at roe can help me out with an answer.
I know something is wrong but i am a dummy when it comes to cars/trucks.
Try doing your own oil consumption test. Make sure your oil is at the right level. drive it for 600mi. then re-check. That is what they did to mine, It was less than a quart so they said it was within standards.2ndchance said:i took a close look and i didnt find a drop!!! no leak ,no puddle, not anything. I wont be able to get her in the shop till monday. i am out of town anyways and she'll be sitting for a few days. i wish i had more experience with this stuff . i will keep u all posted!!!
includemeout said:Are you sure the idjuts are not putting in 11 qts. then saying it is low.
it only holds 8.7 total by factory manuel. if thier using the old compuer data base this could happen. just a thought.
I don't think I agree with it either! How could you burn off nearly half the oil in your truck in such a short time?2ndchance said:thanks joe. i read that tonight. i dont quite agree with it but i dunno. i think they just sent out that memo to cover thier arss.
That was me Silverback. Sorry!Silverback said:I'm within a few miles of hitting 30,000 miles, and mine goes through 2 or 3 quarts between oil changes.
Truthfully I really don't care. I just add a quart when needed and drive it.
Oh, I forget who said it, but the oil ring is on the bottom of the piston, not the top. The top ring is a compression ring.
Didn't want anyone to get confused.
Eddie, how many miles on the rig? and how much oil do you consume?eddie102870 said:mine has never burnt that much oil, id check water, if there'oil in there could be a head gasket.
joemags54 said:That was me Silverback. Sorry!How many miles between oil changes do you drive?
