6pakattack
- Joined
- Jun 17, 2006
- Messages
- 3,575
- Reaction score
- 0
Have you tried pulling a spark plug to check and see what it looks like ?? They can give you a good idea if you're burning it !!!:dontknow:
another good idea!:top:6pakattack said:Have you tried pulling a spark plug to check and see what it looks like ?? They can give you a good idea if you're burning it !!!:dontknow:
18k on mine, never has burnt a drop of oil maybe mines different. but its always full, i run 9 qts. when i change the oil.imho 2 or 3 qts of oil between oil changes is excessive, its got to go somewhere, either out the tailpipe for into water system or on the ground, one of the three places.joemags54 said:Eddie, how many miles on the rig? and how much oil do you consume?
eddie102870 said:18k on mine, never has burnt a drop of oil maybe mines different. but its always full, i run 9 qts. when i change the oil.
Well thank the Heavens!! Your info here is certainly encouraging!. I hope we have more owners in your shoes than not. I only have 1950 mi on my truck but I religiously check the oil. For me, as well, it is a pet peeve. I would still like to keep this thread alive and have as many people as possible "weigh in" on this topic. We may find some help or guidance for the owners ,who have higher oil consumption, than we all might agree is "normal".eddie102870 said:18k on mine, never has burnt a drop of oil maybe mines different. but its always full, i run 9 qts. when i change the oil.imho 2 or 3 qts of oil between oil changes is excessive, its got to go somewhere, either out the tailpipe for into water system or on the ground, one of the three places.
JRSVIPR said:1- quart for 1000 mi. is normal up to the 50,000 mi. mark, Then it goes to 1- quart every 750 mi.
J.R.
This is within standards for almost all DC vehicles.05BLACKVIPER said:holy hell!!!!!!!! check the gas and fill the oil please.
there would be some major problems if ya burn 1qt in 750mi.:dontknow:
Jax Ram said:Check the PCV return line on the passenger side valve cover. I had one crack at 11,000 miles and it used 7 quarts of oil in 250 miles. It only smoked upon modest throttle in first gear. It didn't smoke in any other gear because it was just burning it like gas! Technicians didn't find it until the engine was torn down and then it was found. I was lucky that I checked my oil when i noticed the guage fluctuation. The oil pressure came up fine once there was sufficient oil at idle. I was well in warranty so I got a total engine rebuild at 11,000 miles. Good Luck, Mark
Marc T said:I am with Bucke77 and Silver on this one. It is normal for these engines to consume oil. It is mostly from the crank case pressure which blows the eccess into your intake via the vent.
If you rev it up hard and let it back to idle you will notice a small puff of blue smoke right at the end. Nothing to worry about, you could also get the JMB catch can and monitor how much oil is being blown out of your crank case.
Just a thought!!
I also think what Flyinglow said may very well be true! If you let the dealer change your oil last time they may not have comp[letely filled it??
Fill her up and watch it closely! I think you will find it is consumming oil at a normal rate!!
2ndchance said:I need some advice and help from the experts. Last week i posted a thread about my Psi for the oil gauge dropping to 0 everytime i came to a stop. I took her to the dealer and they told me it was a relay switch that was bad and replaced it. They also did an oil change and told me that she was about 3-4 quarts low. They told me that after 30,000 miles that these engines comsume alot of oil. They told me that this is normal for these engines to comsume at least 1-2 quarts for every thousand miles. They stated that being low on oil also could be causing the problem for the Psi to drop.
My question is what the dealer stating true? After 30,000 mile these trucks eat up that much oil???
Anyone else having this problem??
-OR-
Am I facing a more serious problem and the dealer just doesn't want to fix the real problem. I am no genius but i don't think it is normal for the truck to comsume that much oil with in 2,000-3,000 miles.
PLEASE HELP ME!!!!
JRSVIPR said:Here it is he-he. :dontknow:
J.R.
Sorry it was not sooner, It takes me awhile to things worked out. Damn computers. ( Not operator error )2ndchance said:Thanks!!! I printed it up and I am going to have the dealer go through the steps of provided on the form. Thanks again.
Sorry it was not sooner, It takes me awhile to get things worked out. Damn computers. ( Not operator error )2ndchance said:Thanks!!! I printed it up and I am going to have the dealer go through the steps of provided on the form. Thanks again.
