Would it be less time consuming to email? Or time consuming either way? I think all I really need is a wiring diagram of the 3rd plug into the ECU (comes from body harness, believe it supplies power/gauges). If you're looking at the ECU with pins to the top, it's the Left plug. Other 2 plugs are engine harness only.
The more I read, I think I may end up needing the after market harness and ECU flash to get past the theft key anyways. I don't have a key/ignition or the body control module (only have stock ECU), so I'm assuming that'll be very difficult to bypass.
POWERTRAIN CONTROL MODULE C1 (SRT) - BLACK 32 WAY CAV CIRCUIT FUNCTION
1 K133 18DB/WT COIL CONTROL NO. 4
2 F202 18PK/GY FUSED IGNITION SWITCH OUTPUT (RUN-START)
3 K18 18DB/OR COIL CONTROL NO. 3
4 K900 18DB/DG SENSOR GROUND
5 K134 18DB/YL COIL CONTROL NO. 5
6 - -
7 K19 18DB/DG COIL CONTROL NO. 1
8 K24 18BR/LB CKP SIGNAL
9 K17 18DB/TN COIL CONTROL NO. 2
10 K60 18VT/DG IDLE AIR CONTROL NO. 2 DRIVER
11 K40 18BR/LG IDLE AIR CONTROL NO. 1 DRIVER
12 - -
13 - -
14 - -
15 K21 18DB/LG IAT SIGNAL
16 K2 18VT/OR ECT SIGNAL
17 F855 18PK/YL 5 VOLT SUPPLY
18 K44 18DB/GY CMP SIGNAL
19 K39 18VT/LG IDLE AIR CONTROL NO. 3 DRIVER
20 K59 18BR/DG IDLE AIR CONTROL NO.4 DRIVER
21 - -
22 A919 16RD FUSED B(+)
23 K22 18BR/OR THROTTLE POSITION SENSOR SIGNAL
24 K41 18DB/LB O2 1/1 SIGNAL
25 K141 18DB/YL O2 1/2 SIGNAL
26 K43 18DB/LG O2 2/1 SIGNAL
27 K1 18VT/BR MAP SENSOR SIGNAL
28 - -
29 K243 18BR O2 2/2 SIGNAL
30 - -
31 Z130 16BK/BR GROUND
32 Z131 16BK/DG GROUND
POWERTRAIN CONTROL MODULE C2 (SRT) - WHITE 32 WAY CAV CIRCUIT FUNCTION
1 - -
2 K26 18BR/YL INJECTOR CONTROL NO. 7
3 K115 18BR INJECTOR CONTROL NO. 9
4 K11 18BR/YL INJECTOR CONTROL NO. 1
5 K13 18BR/LB INJECTOR CONTROL NO. 3
6 K38 18BR/OR INJECTOR CONTROL NO. 5
7 - -
8 - -
9 - -
10 K20 18BR/GY GEN FIELD CONTROL
11 - -
12 K58 18BR/VT INJECTOR CONTROL NO. 6
13 K28 18BR/LB INJECTOR CONTROL NO. 8
14 K116 18BR/WT INJECTOR CONTROL NO. 10
15 K12 18BR/DB INJECTOR CONTROL NO. 2
16 K14 18BR/TN INJECTOR CONTROL NO. 4
17 C240 18LB/TN HYDRAULIC COOLING CONTROL FEED
18 - -
19 C918 18BK/LB A/C PRESSURE SENSOR GROUND
20 - -
21 K333 18DB/LB SOLENOID REVERSE LOCKOUT FEED
22 - -
23 G6 18VT/GY OIL PRESSURE SIGNAL
24 - -
25 - -
26 - -
27 B22 18DG/YL VEHICLE SPEED SIGNAL NO. 1
28 - -
29 - -
30 - -
31 F856 18YL/PK 5 VOLT SUPPLY
32 - -
POWERTRAIN CONTROL MODULE C3 (SRT) - GRAY 32 WAY CAV CIRCUIT FUNCTION
1 C13 18LB/OR A/C CLUTCH RELAY CONTROL
2 - -
3 K51 18BR/WT ASD RELAY CONTROL
4 V36 18VT/YL S/C VACUUM CONTROL
5 V35 18VT/OR S/C VENT CONTROL
6 - -
7 - -
8 K99 18BR/LG O2 1/1 HEATER CONTROL
9 K127 18BR/OR OXYGEN SENSOR DOWNSTREAM RELAY CONTROL
10 K106 18VT/LB LEAK DETECTION PUMP SOLENOID CONTROL
11 V32 18VT/YL SPEED CONTROL SUPPLY
12 K342 16BR/WT ASD RELAY OUTPUT
13 - -
14 K107 18VT/WT LEAK DETECTION PUMP SWITCH SENSE
15 K25 18 DB/VT BATT TEMP SIGNAL
16 K199 18BR/VT O2 2/1 HEATER CONTROL
17 K90 18LB/TN ENGINE STARTER MOTOR RELAY CONTROL
18 - -
19 K31 18BR FUEL PUMP RELAY CONTROL
20 K70 18DB/BR EVAP PURGE RETURN
21 - -
22 - -
23 - -
24 B29 18DG/WT BRAKE SWITCH SIGNAL
25 K125 18BR/DG GEN SOURCE
26 N4 18DB/WT FUEL LEVEL SENSOR SIGNAL
27 D21 18WT/BR SCI TRANSMIT (PCM)
28 - -
29 D20 18WT/LG SCI RECEIVE (PCM)
30 D25 18WT/VT PCI BUS
31 - -
32 V37 18VT S/C SWITCH NO. 1 SIGNAL
