sleeper
Hey Fred. You must love doing cams.
Trans started slipping on the way home today so thats one more delay and another 2 grandTooloe said:don't give up!!! don't do it... once you get the tune right that thing will fly! can i had my QC hemi "5.7" pushing 450 hp with a 50 shot of spray... it's in there just keep messing with it
Damn hot rodding expensive.OSO said:Trans started slipping on the way home today so thats one more delay and another 2 grand
slow91 said:Looks like you're on to something. Good luck with the tranny issue.
Btw, all these posts about driver..... ....it's an auto right?? How much skill does it take to stomp on the throttle and go in a straight line???:marchmellow:
davo19 said:check www.rumblebee.org, there should be some others there with similar mods and good info...[/QUOTE
Motors have been built but only one person i know of has done the 727 trans swap and i don't know of anyone using a gm trans in a late model Ram.
OSO said:Im back on track my Gear vendors under overdrive unit showed up today for my 727 .
blackviper said:Nicely done. Don't give up.
NightRunner385 said:You mentioned using a GM tranny earlier, so I thought you might like to see this:
http://www.keislerauto.com/index.php?/mopar-automatic-overdrive-stage-3-650-lb-ft-basic-kit.html
It's a 4L60E modified to go on a Mopar bolt pattern. Not sure if it will work for your application, but maybe worth checking out?
