NEW MULTI GUAGE
Is there an additional part needed to read boost/vaccum from a MAP sensor got our trucks? I saw there's a GM sensor and a 3.5 bar one but I only have a 2 bar. My current boost gauge is crapping out.
What color will the display be? I see they have one with green numbers and letters. That looks like it would match our gauges the best. Especially at night.
just a reminder i need the silver face with a brushed alum bezel so check on price diff if theres one i jus cant put a black gauge in the truck will kinda look like it dont belong
map sensors
GM style 2 Bar MAP with connector/pigtail:
- Reads up to 15 psi
$55
Wide band O2 sensor kit for Air/Fuel ratio:
Each kit consists of a sensor, controller, steel bung, and cabling allowing you to connect directly to the Interceptor gauge. These accurate sensors use the new Bosch LSU4.9 sensor and are available at a very affordable price.
$189.00
Oil and Fuel pressure sensor kits:
Each kit consists of a sensor and connector/pigtail. These accurate sensors have NPT fittings, 0-5v outputs, and of course are compatible with our gauge products.
$65.00
5v regulated power supply
Simply connects to switched 12v and ground to supply 5v to our sensor kits. Eliminates the need to tap into other sensor lines or the PCM to obtain 5v.
$23.00
Temperature sensor kits:
Each kit consists of a sensor, signal conditioner, and connector/pigtail allowing you to connect directly to the Interceptor gauge. These accurate sensors are OEM units and are available for use for fluid or air temperature.
$44.95
2000 psi Nitrous Sensor
High accuracy (.5% FS) sensor with 1/8" fitting. Easily connects to the Intercetor gauge allowing you to monitor and log pressure.
$98
guage faces
Custom Faces:
Gauges come configured with a black face and black bezel with an included white face and polished silver bezel. Additional optional hardware such as silver face or brushed aluminum bezel can be ordered
guage face color
Another menu option offers the ability to swap the foreground and backround colors of the display (as pictured below). Using this feature, for example, the gauge with a black backround and blue characters (negative image) becomes a blue backround with black characters (positive image). Not only can this be visually appealing but beneficial in changing lighting conditions. Positive images are easier to read in bright sunlight, negative at night.
THESE WILL BE ORDERED WEDNESDAY, ANYONE INTERESTED NEEDS TO CONTACT FOR PAYMENT, T
THANKS
good info if you can find out the price diff on a silver face and silver bezel i will pay ya 2day bud! jus shoot me a text when u know a total:D
JTS VENOM PERFORMANCE said:
map sensors
$55
$189.00
$65.00
$23.00
$44.95
$98
guage faces
Custom Faces:
guage face color
THANKS
Do we still need their map sensor, even though some of us are running the SRT4 map sensor? Shouldnt the gauge be able topick up this signal from the PCM? The PCM is definitely reading the boost, that's how it comtrols timing under boost.:dontknow:
yes it should , just adding all the accessories they offer
The gauge comes configured with a black face and bezel but a polished aluminum silver bezel and white face are included.
any xtra bezels or faces are $10 xtra sir
all guages are ordered for those that ordered , special pricing ended
thanks bob
Where's mine? I want my gauge!!! Now!!!!
