NEW MULTI GUAGE
Jfireboy1 said:
10-4!!! One of the best things if I'm not mistaking is that it can record upto one minute of info , so say if you run a 1/8 or 1/4 and wanna know what everything is doing it will data log what your reading were during your run for upto one minute!!! :rock: . Man ! Come to think of it Tony I don't know if one minute is long enough for Santeen to run the 1/4!!!! Lol! Might have to check if they make one that will do atleast 1 1/2 minutes! Lmao!!!! :D ! What's up Steve if u r watching!?!?! Lol
LOLOL with Steves truck we may have to make sure it records days:D
You STFU!!!!. Too bad you're working next friday. :aetsch:
You wanna get kicked in the nuts?!?!?!?!?
No! You r lucky! I would hate to have to of beaten you after all that work putting in that converter! :d
actually I rather enjoy that:D and I just charged your card for two of these guages, one for fireboy and one for viper, would you like one?:D
:rock: :rock: :rock: :rock: :rock: :rock: :rock: :elefant:
:D :D :D :D :D :D :D
gonna get my info to them fellas and get this all together, and will get a list of guys that want in on the first order, and we all know how I do first orders sooooooooooo;)
im n i want 1 as long as its purdy!!!!!!1 so i needs to be on that 1st order lol
"they measure more things then I thought the computer knew, batt temp, boost,knock spark advance, how long the injectors are open , I mean everything, I need to add the a/f to it but other then that really easy to set up, they have the annuciator setup you can change for any parameter to flash the lights at you rpm, a/f mph what ever, and super easy to install just plug in,"
from an earlier pm
Approximate cost on this new fangled device would be what Tony????
What would be needed to moniter A/F, separate guage, extra bung for O2 sensor or would it read off factory sensor.
o2 sensor and bung and the cable , it plugs straight into the unit
If you have an AEM gauge, you can use the 5 volt ouput and attach it to the 5 volt input on the aeroforce. This would be helpful when in record mode, to see your A/F readings during a run.
How much more would it cost for O2 sensor, bung and cable that is needed to read A/F from this gauge. I am assuming that's all I will need + your gauge
singles are $249 duals $399 but like allways I will do special pricing on initial orders buddy
