ok think I have it all finalized fellas, I will send out some pricing monday or tuesday on this, I jsut wanted to make double sure of what things it would do on our trucks
and patrick they have one for the newer vipers now also sir
On the truck and 2007 and older Viper they can display:
Intake air temp
Coolant temp
Mass Air Flow (MAF)
Manifold Air Pressure (MAP) – this will be displayed as both absolute and boost pressure -if car has a MAP sensor
Ignition advance
Long term fuel trims
Short term fuel trims
O2 sensor mv’s
Closed/Open loop fueling status
Engine load
Throttle %
MPH
RPM
HP
MPG
Battery Voltage*
Engine Run Time*
Commanded A/F ratio*
Analog input 1
Analog input 2
*Not all cars support these parameters
The 2008 and newer have more, oil pressure, inj pw, both intake temps, and a few others
Intake air temp
Coolant temp
Mass Air Flow (MAF)
Ignition advance
O2 sensor mv’s
Engine load
Throttle %
MPH
RPM
HP
MPG
Battery Voltage*
Engine Run Time*
Analog input 1
Analog input 2
