newmexicoviper
Ok guys ill get as much info down as possible & pic's will follow tonight. So here goes!
First we gutted the truck, ran Monster cable for the amps & components then installed Stinger Road Kill Extreme Matt, Next we get to the meat & potatoes of the install we used Focal K2 Power Component set in the front (which includes (2) 6 1/2 Woofer's (2) TN-52 Tweeter's & (2) Adjustable Crossovers, onto the back we used (2) Focal 130 CA1 5 1/4's Woofer's in the rear doors. Now for the amps we used (2) Focal 4 channel 4X400W bridged RMS mounted under the driver & passenger seats we used one amp to power the box & the other amp for the doors & tweeters, we removed the passenger side jack put the amp powering the box & both crossovers under that seat. The box like some of you may know is a Power Box the new design they have for are trucks holds (2) Super 8's in a "vented" CNC cut wood box / encloser thats coated with something along the lines of Rhino but smoother and cleaner. I wanted to keep my stock deck with the navigation & blue tooth link + it saved me some money. So to make all this work we went with a Peripheral PCH8 Line Converter with a gain controller for turning the bass up and down depending on choice in music it is one of the reasons this system really rocks:rock: it really a top notch component with it we were able to tune the system in to perfection (if you like my types of music) using a RTA Real Time Analizer. The only stock pieces left as i have said the factory deck the factory in dash amp that we used to power the deck & the stock center channel speaker in the middle of the dash. If you were to look into my truck you couldnt tell that it had one of the cleanest hard hitting sounds systems around. There ya go i prolly forgot a few things but ill tell ya call my buddy Jim Perdue Mc-Due Ultimate Audio @505-324-8459 he is the master mind behind this thing and can answer all you tech questions pertaining to this project.
