HISS...where are you getting the truck dynoed?...ive' been meaning to get mine done too.what dealership do you work at?
That was at a test n tune night not a raceAWDisuzu said:your run with spray video just shows you getting creamed. and no time?
SANCHOBA said:HISS...where are you getting the truck dynoed?...ive' been meaning to get mine done too.what dealership do you work at?
BigRed460 said:A bog normally means to much fuel, if it puddles in the intake your get a Nitrous backfire that blows apart the intake, I have seen quite a few pictures of our trucks doing this...
Seems to be, more bottle pressure, and I just took the nozzles out of the intake tube and installed them in the upper intake. Its very similar to JMB Justins setup, and of course thats where the inspiration came from. I will see how it works when its all reinstalled.FATJACK said:Did you get your Nitrous working right??
Good read!FerrariTruck said:You need a bottle Warmer!! I would never spray with pressure that low..At the very min 925... I know this is hard to believe but you can do more damage with system on the rich side then a tad lean....
The 850 you had will make it bog...
Read this link, I'm actually thinking of taking this class
http://www.smotherssupercars.com/nitrousclass.html
You did not purge enough, I did that a couple times before I figured out wtf.HISS said:Talked to Cold Fusion Nitrous this morning, they told me low bottle pressure can cause this, but it only bogged on initial hit, I sparyed in 2nd third and fourth and had no hesitation. Its got me a little puzzled.
I purged for a good 4 to 5 seconds.DevilDawg3097 said:You did not purge enough, I did that a couple times before I figured out wtf.
was 12345 or 1 1/1000 2/ 1/ 1000 or 1 mississippiHISS said:I purged for a good 4 to 5 seconds.
