Aussie Viper Truck
you can also try this; unscrew the oil filter until the seal just come away from the sealing surface, then get someone to start the engine as you watch for oil to come between the filter and block. this works on Kawasaki motorcycles that loose oil pump prime. unscrewing the filter makes the oil system have no restriction and the pump has its best chance of moving oil. once you get oil at filter stop engine and do up the filter and then start engine, or do the filter up while engine is running. both ways will be a bit messy. hope this helps
