One Set of MOPAR long tube headers and mids
Mine are coated inside and outside...the coating is thicker on the inside...there is an article in last months Hot Rod Magazine...check it out...I have no problem with melting.
There are differences in coatings....ceramic not near as good as jet hot.....I think Prof has the jet hot....I know a guy with an SRT8 and jet hot headers...you could hold your hand on his headers after the car was turned off for 5 minutes..try that with ceramic...
I thought Jet Hot WAS ceramic ?
If it isn't,what is Jet Hot ?
Mine are ceramic coated by AirBorne and seem to work fine (the stainless ones on the 99 Ram)
The jet hot is a type of ceramic but I am not sure the exact diff....the ceramic coating like on the Bassani shortys will not turn heat near as good as jet hot coating inside & out.....someone will chime in with a more tech answer..
Prof said:
200 is a huge number...but easily 75 to 100.
your probably right:rock: I'm not 100% sure on what the difference was exactly,it was quit a difference,but you know how the stories change as they get sent down the latter:D
