- Joined
- Nov 1, 2009
- Messages
- 792
- Reaction score
- 5
I have been having issues with starting my truck the proper 710 cam supercharger tune. Long cranking... Sometime when it's warmed up it would stall on deceleration and ping around 2500rpm under 1/2 gas with 7#s boost.
So I would load the old supercharger tune that runs 6-7#s and 42#injectors to get the truck running (rich 12.2 at idle) for a few minutes then swap the tune. I did this for a weekend. Then last weekend I was insulating my garage so I pulled the truck out took me a couple minutes to get it running on the proper tune but it started pulled it out if the garage let it warm up befor shutting it off (-17C) then 8hrs later it wouldn't start so I tried to load the other tune that has worked and it failed to load, the tried to revert to stock and it fails at 1%. I tried to day since its warm out the sct says return to stock and fails at 1% and I have the P0601-PCM INTERNAL CONTROLLER FAILURE
I found a post on another srt forum of a guy with a 05qc with this problem. My tuner says to send the sct and PCM to sct to unlock it and see if the can reset the PCM I do have a new PCM on order.
