Hope this helps
Possible Causes
GOOD TRIP EQUAL TO ZERO
(A14) FUSED B+ CIRCUITS
(K342) ASD OUTPUT CIRCUIT OPEN
PCM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure)
1.GOOD TRIP EQUAL TO ZERO
1. Ignition on, engine not running.
2. With the scan tool, read DTCs and record the related Freeze Frame data.
Is the Good Trip Counter displayed and equal to zero?
Yes
Go To 2
No
Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure).
Perform POWERTRAIN VERIFICATION TEST.(Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure)
2.ENGINE STARTING STATUS
1. Attempt to start the engine.
Did the engine start?
Yes
Go To 3
No
Go To 4
3.(K342) ASD OUTPUT CIRCUIT OPEN
1. Turn the ignition off.
2. Disconnect the TIPM harness connectors.
3. Disconnect the PCM harness connectors.
4. Measure the resistance of the (K342) ASD Output circuit from the TIPM to the PCM harness connector.
Is the resistance below 5.0 ohms?
Yes
Go To 6
No
Repair the open in the (K342) ASD Relay Output circuit.
4.(A14) FUSED B+ CIRCUITS
3. Using a 12-volt test light, probe the (A14) Fused B+ circuits at the TIPM harness connectors at the PDC.
Does the test light illuminate brightly?
Yes
Go To 5
No
Repair the open or short to ground in the (A14) Fused B+ circuits. Inspect the related fuse and repair as necessary.
5. (K342) ASD RELAY OUTPUT CIRCUIT OPEN
1. Disconnect the PCM harness connectors.
2. Measure the resistance of the (K342) ASD Relay Output circuit from the ASD Relay cavity in the PDC to the PCM harness connector.
Yes
Go To 6
No
6.PCM
NOTE: Before continuing, check the PCM harness connector terminals for corrosion, damage, or terminal push out. Repair as necessary.
1. Using the schematics as a guide, inspect the wire harness and connectors. Pay particular attention to all Power and Ground circuits.
If there are no possible causes remaining, view repair.
Repair
Replace and program the Powertrain Control Module per Service Information.
