vvv90
Can someone give me the manufacturer's part numbers for the Centerforce Clutch and Fidanza flywheel?
Thanks!
Thanks!
FSTJACK said:JMB Juusin has the complete package that you need.
He is also a vendor here Roe is not. Support the people that support us.
Nowwhat said:Since you mention it that way.....
Thought it was interesting that 1fastdumdum is taking off his roe TMTS and going with a paxton.....
vvv90 said:That and I'm still up in the air about going to an aluminum flywheel. A couple people are telling me it's not good for such a heavy vehicle.
It's not a matter of the Fidanza failing. The argument is that the truck would be quicker in a drag race with the OEM flywheel because the heavier rotating mass will help with torque.mauiSRT/10 said:I hear what your saying..................realize this, VPRPWR has run his Paxton/Nos truck down the track over a hundred times with no problems with the Fidanza lightweight flywheel and Centerforce clutch.............if he isnt the fastest RC, he is the second fastest .....(srt10x3's TT RC ran a 10 something). Point being, the flywheel will hold up. I have yet to hear of one fail in the 3 years of having my truck.
patrick
ViperTruck2933 said:It's not a matter of the Fidanza failing. The argument is that the truck would be quicker in a drag race with the OEM flywheel because the heavier rotating mass will help with torque.
No prob! :rock:mauiSRT/10 said:Thanks Tim, I did not know that. Thats why this site rocks!!!:rock:
patrick
Several have resurfaced. None have had issues that I am aware of. Mine will be getting resurfaced soon. :burnout:vvv90 said:So I've heard people have, in fact, resurfaced their OEM flywheel, is that true????
ViperTruck2933 said:Several have resurfaced. None have had issues that I am aware of. Mine will be getting resurfaced soon. :burnout:
ViperTruck2933 said:I think a new OEM flywheel is under $200. But you can get resurfaced for probably under $20.
I kept driving my stock clutch after I smoked it and it reseated. Hasn't slipped a single time on me since it smoked. Even with all the added torque of my heads/cam it's still holding strong. I'm going to the track with drag radials next week though so I don't know how much longer I'll be able to say that.
ViperTruck2933 said:As long as it's not warped or otherwise damaged I don't think it'll hurt to resurface it. You just have to make sure it only gets a little bit shaved off. If it needs alot taken off then I'd get a new OEM.
