Paxton Novi 2000
Heart Attack said:
also 63lb injectors with sct
And ur running that lean with Torrie's base tune or is it someone else's tune? His base Paxton tunes are very safe
it will fluctuate all over the map at idle, and have a bit of variance at cruising...
it's under WOT that she should hold steady, and ideally be in the 11.5 range...
Heart Attack said:
so what should it be reading at WOT? 11.5?
Yes, around 11.5 at wot is pretty safe. 12.0 on a stock bottom, under boost, is the most u wanna see. But, like Dan said, at idle and cruising it'll be all over the place. That's fine. Just worry about wot. Who did ur tune?
viperhauler said:
my bro's srt4 (which runs mid 8's on street tires on a 100* day) runs 11.7 at WOT, i believe...
And that is pertinent information, why? So ur brother hangs with u in the 1/8th? :D
Heart Attack said:
ok so i hit WOT and i was around 11.2-11.7 in that area. im good to go right?
Yup, that looks good. Give it a good wot run from about 2nd gear up until it shifts into fourth. And just make sure it doesn't go above 12
I think those are ridiculous numbers for the mods you have done. Santeen's truck runs great too.
Maybe I should just get a Paxton, a clutch upgrade and be done... for awhile.
Now ur talkin'!!
