bassfrad
Any one know of a good place to take my 2006 SRT-10 to have turbos, retune and a 6 speed manual trans installed around Dallas,Tx:dontknow:
you are correct i'm still waiting for them to have the time to get my truck back in down thereJTS VENOM PERFORMANCE said:from what I understand ART is under new managment, you might give them a shout, supposed to be moving there shop soon to the strip
talked to the new owners , they sound pretty cool, sounds like they may turn the place the around a bit:rock:Tooloe said:you are correct i'm still waiting for them to have the time to get my truck back in down there
Tooloe said:dallas performance
no turbos , if you dotn want to do engine work, best stay away from those, others will def dissagree, but eh, you will blow with a turbo and oem internals,it will happen.bassfrad said:I'm not wanting a big turbo just a little more than what I have now. What can I get away with without blowing engine?
you would think , but not the case, I thinkk prof has a pic of the oem pistons here somewhere, but the top ringland is very close to the top of the piston, more than a normal piston should be, so under compression the ring land will eventually crack and thus fail, and if your lucky the piston dont come all the way apart and break the powder stamped rods and put a window in the blockbassfrad said:I have rebuilt several engines, mostly chevy 350's but I'm not understanding what the problem is with the ring lands. You would think this engine would be built super strong from the factory.
Whats push tubes and stinker oil cooler lines. whats wrong with my cooler lines.:dontknow:ZCx said:forge it!!!!
go with pistons, rods. check crank for straightness. out of spec go forged. billet main caps, studs & bolts.
good push tubes
a set of Stinker oil cooler lines
etc.
OCBob said:I can't believe that not one single person has recommended Hennessey.
heheheh, sorry just couldn't resist.
