Hope these pics get to you.http://s264.photobucket.com/albums/ii185/SERPENT010/
That's a Weldon regulator. We replaced the Paxton fuel pump with an aeromotive eliinator and ran braided lines to boomers fuel rails. We used the stock fuel line as a return back to the tank. With new fuel system,60 lb injectors and meth injection we made 670 rwhp and 675 ft lbs torque.kyle's srt10 said:What is that in the middle of you intake manifold:dontknow: What #'s you put down![]()
thanks great numbersSERPENT said:That's a Weldon regulator. We replaced the Paxton fuel pump with an aeromotive eliinator and ran braided lines to boomers fuel rails. We used the stock fuel line as a return back to the tank. With new fuel system,60 lb injectors and meth injection we made 670 rwhp and 675 ft lbs torque.
Thanks-The brake light really looks good when lit. The Aeromotive fuel system was the best way we could get the A/F ratio down from a way too lean 13.2. Only downside is that the pump is noisy at startup.Stinker said:Thanks for the pics bo:rock:
sweet set up:rock: and the first true fuel system I have seen:rock: :rock: :rock:
Killer numbers!
