You still in Sacramento? EED just moved to Reno. That would be the closest place that I know of that knows there stuff.
kickinassrt-10 said:Just saw your vid.....what is the fluid under the exhaust? when my head gasket warped it did the same thing..leaked fluid and went from light-no smoke into enough smoke to make it's own weather system.....the gauge looks like water affected it for the time being
yea forgot that he said it smelled like gas....let us know what the cause was when you find out...FerrariTruck said:I doubt that its a head gasket at this time, but If you'd to make a quick test to see if you are getting some leakage you use this block tester which turns color if there is hc's in the coolant.(meaning headgasket or cracked head, etc..) avail at your local napa and very simple to use. just need to remove rad cap after engine warms up
http://cgi.ebay.com/ebaymotors/Comb...Z220412122627QQptZMotorsQ5fAutomotiveQ5fTools
try unhooking the vec, but dont drive it far, hell stop traffic if you have to bud, but it shouldnt cost much, heck if you check in the morn it might run fine, but the oil will need changing, but changing the card want help on this one I am afraid, you could try tho.LoveThisTruck said:Thank you guys for your input and advice. Many of the things suggested are way beyond me lol. I'm a helicopter mechanic... I don't know much about things that have 4 wheels and an engine with pistonsIt's going to people who know what they're doing.
We'll find out what's going on shortly.
The truck will be loaded on a trailor in the morning and taken down to A&C. I might have to drive it a short distance to get it to a spot where it can be loaded up. The little parking lot it's in now just isn't gonna cut it. Will it be alright? Should I unplug the VEC? I have a VEC card that's another -4 degrees timing... should I throw that in???
Man, I hope this doesn't cost me too much. #270 might be down for a few months![]()
Stinker said:try unhooking the vec, but dont drive it far, hell stop traffic if you have to bud, but it shouldnt cost much, heck if you check in the morn it might run fine, but the oil will need changing, but changing the card want help on this one I am afraid, you could try tho.
If the VEC did get fried how much work is it to get the SCT installed instead of a new vec? Do the wires from the VEC install need to be returned to stock? I have no idea. Just wondering if that is an option for you.LoveThisTruck said:I might have to move it a 1/10th of a mile or so to a bigger parking lot.
Could the VEC be fried if it did get wet? That's an easy $1000 right there
Then there's the burning oil issue, It's under warranty, and I can't think of anything that I could have done to cause that.
Anybody wanna buy a truck???![]()
dude calm down, for once give me some trustLoveThisTruck said:I might have to move it a 1/10th of a mile or so to a bigger parking lot.
Stinker said:dude calm down, for once give me some trust![]()
sit back , play with ya pud, and smile![]()
your vec is most likely not fried, jsut wet, mine stayed that way for two days once.
the smoke is most likely from all the fuel it is burning,
now I could be wrong, but it is exactly the same symptoms as I had TWICE
jsut be sure to change the oil asap, have it checked out, but persoanlly and I hope to jesus I am correct, but think you will be ok![]()
good deal bo, whats done is done, and cant be changed tonight, and I hope you will be surprised at the outcome,LoveThisTruck said:LOL I'm calm... got a few beers in me nowI just can't afford this shit right now bro
I'm gonna go play with my pud
