ZCx said:is she fixed ?????? :dontknow: :rock: :dontknow: :burnout: :dontknow: :burnout: :congrats:
We think so. He's gonna put some more miles on her... make sure it's not burning oil anymore:burnout:
LoveThisTruck said:We think so. He's gonna put some more miles on her... make sure it's not burning oil anymore:burnout:
LoveThisTruck said:Thanks guys... a relief for sure:rock:
Todd, I'll give you a call on Monday. I wanna talk to you about a breather system/catch can, as well as relocating that VEC. I would really like to know what you think caused this. I know part of it was me getting the VEC wet:argh: but why was it burning oil in the first place? Did the rings just not seat right?
:rock: Thanks man, I'll let you know if I don't relocate the VEC.SrtBrad said:I have a vec3 hard plastic cover that I'm not using. You can have it if you want. I forget which vendor I bought it from but it's new and perfect shape.
bigike said:I think we need a pcv system in these engine. To much crankcase pressure.
Good to hear she is back up!
TNVIPER said:Buy the extension from Roe and put that VEC in the cab. Not only keeps it dry but you can change tunes w/o leaving the cab...had mine mounted under the dash to the right of the steering wheel.
LoveThisTruck said::rock: Thanks man, I'll let you know if I don't relocate the VEC.
I've been talking with Stinker about an evac system... I think I might try it.
Is it easy to do? Where does yours come through the fire wall?
I was thinking about putting it there, or in the glove box:dontknow:
Prof said:Mine is in the same place...
NBT said:FYI there is already a hole for the vec in the back of the pocket in the truck...It was there...but I was having problems with the extension harness, and dropping tunes...so we reloacted it to where it was when you got it...and I never had a problem with it after...here is the pic from inside the cab....notice ALL the lights were on...:argh:
Happened to Jack and I at the Mopar Nat's, and the tune reloaded without incident...IF you relocate the VEC into the cab...ground it nearest to the VEC as possible.![]()
FYI...it was slid out due to the prior issue...which I never had the entire trip...until I was returning from the track...reloaded the tune, and raced the rest of the weekend...drove it home (1100 miles) without a problem.
THEWELSHM said:The gear knob needs to be turned to the right Prof![]()
thewelshm
