Floor
FSTJACK said:I have had a set of QA1s on the red truck for 12K miles, and they installed just like Carls. So far no problems.
There is not an aftermarket shock that will fit our trucks correctly.
The rear sway bar mounting holes are not the same from week to week on most trucks, as so many running changes were made to the trucks.
I had to drill out my sway bar link mounting holes on the frame bracket to get a larger bolt in. Some fit and some don't. The 04s and 05s were somewhat alike but the 06s are a breed onto themselves.
That is what we all have to deal with, beacuse it is a limited production vehicle. Yes it is a pain in the rear, but after a while you get used to having to make most things on a very custom basis.
I recently had an experiance with a big time aftermarket front end fabricator/manufacturer that swore to me ( 3 different people at 3 seperate times ), that their air ride kit would fit. Well after I had the front suspension peeled apart there is no way that it would work even with major modification. I am out of pocket about 900.00 for shipping and other costs directly related to this fiasco. I have just learned to suck it up and move on. It is truly not worth wasting energy on as that will still not get the end result I need.
I will try again, this time with a custom fabricator in SanTee that builds trophy trucks and class one cars. We are going to have to do some very unconventional things to get the results I need.
The bottom line is every time I change something from stock I will really not be surprised if the modification takes some modifying to work correctly. This is true with all hotrods, and the truck is a factory hotrod.
This is what makes modding and hotrodding such fun, "making things work".
I agree. Only thing I'dd like to add is "SRT 10 kit" should fit spot on. If it needs additional adjustments and even extra parts, it should be mentioned beforehand so that people who don't want/can do the modding know what to expect. If you buy an aftermarket kit of a Hemi RAM you know you might have to do some finetuning. When it is mentioned SRT it should be another story. A manual/instruction is also the absolute minimum IMO.
Carl, thanks for sharing your experience. I'm sure both of you will work it out.
