race fuel advice
JTS VENOM PERFORMANCE
Preferred Vendor
SRT10 heaven
Need some advice on race fuel, cant seem to find anyone local that has the vp c-16 I need, but just down the road at doug herberts they have the torco.
here are the specs on both
http://www.torco.com/cart.php?m=product_detail&p=44
C16
Used in turbocharged engines, blown engines and nitrous applications with CRs up to 17:1. Recommended by the top nitrous oxide companies. Spec Fuel for NHRA Comp Eliminator.
• Color: Blue
• Motor Octane: 117
• Specific gravity: .735 at 60° F
Mach 116
Typical Properties
Color : GREEN
Specific Gravity : .735
Pump Octane (R+M)/2 : 116
MON : 115 RON : 120 +
Reid Vapor Pressure : 7
Distillation : F
10% Evap : 170
90% Evap : 221
End Point : 244
Dielectric = -0.0
For sophisticated applications set ups for Stock Car, Late Model, Modified Sportsman, Enduro Racing, Bracket Racing, with compression ratios 15:1 @ 8500 RPM.
anyone with ideas?
never heard of torco?:dontknow:
but its readily available 5 minutes from the house.
or if anyone knows of a vp sales in mooresville or surrounding it would be appreciated too:D
Lees cycle in charlotte has it , but wants to rape me for $80 for 5 gal , when I know its only $11 or so a gal;)
oh and gotta haul butt to hickory right quick be back in a tiddly
I Mix 32 Ounze of torco On Every Fill Up:rock: Vic Hubbard sells 110 Unleaded octane. 8.00 bucks a Gallon:dontknow:
Why:dontknow: :dontknow: :dontknow:
Because My Aggresive ass Stage 2 Flash From Dan:dontknow: I just filled up with 100 At the 76 Pump In Redwood City (south Of San Francisco) 190.00 to fill up. Than I go have fun and Mess around And 3/4 is gone by the end of the day:rock: :rock:
Annu,
I think you should let one of your wives drive. Might be cheaper... :p
If I were you I'd send the pcm back to Dan, and have him change it to work on our shitty 91 octane gas. Then save all that extra money up to buy more mods.
:D
Annu, that sounds like a blast :rock:
All except the $190 :D That is a lot of lap dances you are giving away ;)
Torco makes an accelerator, its far cheaper than the fuel... and very close to race fuels. I just talked to them on the phone and here is what they provided to me:
When mixed with 91 Octane you get:
1 qt to 20gal = 96 octane
1 qt to 15 = 98 octane
1 qt to 10 = 102 octane
1 qt to 5 = 104 octane
He made to note ITS NOT a octane boost, its the same base chemicals they place in race fuels, has lubes, etc..
Cost is $19.95 / qt or $148.60 for 5 gallon pail, which makes it $7.43 a qt.
If you mix with 93 octane, just add 2 more points to those above numbers.
Awdisuzu uses this stuff....reallly....really...works....:rock:
I Use Torco Al the time too! But when I make More In My Business I fill up with 100 Octane everyweek:rock: :rock My daily driver is a 1998 Dodge ram. For the weekend Viper and Mercedes S600
Tony I have used Torco, you will be fine it is a good product.
Bill.
yes, I do use torco but only in the srt-10 and only because it's got a 93 tune.
I would go for race gas for a engine needing 110+ octaine. you can get it shipped in 55 gal containers.
~Mike~
fast fred said:
i know the higher oct. burns hotter but does it make your motor run hotter?:dontknow:
Why do you think that Octane makes it run hotter?
Octane is a measurement of the ability of the fuel to not detonate. Octane by it's self does not add hp. There is no added BTU's in octane.
on the other site i was told that higher octane #'s burns hotter......:dontknow:........why does every one want higher octane if it does not add H P?
Ok I am back, and the only thing we have assertained is Annu needs another tune:D
Nowwhat and Begood, is it as good as VP?
I have a ton of faith in VP ,used it for 10 years or so, I know the torco will probably work, just want to make sure the specifics of it are the same as the C-16
