Stick with the stock type plugs, no need for anything else.
Ditto!
Well, too late on the plugs. I replaced them with the same type. They were actually in there for about 26,000 miles after I thought about it some more and I never had issues with them until 3 days ago. Well maybe not...
Anyway, it was not the problem. It seems to do it as it gets from cold to hot in operating temperature. It did it after I let it run it run for about 5 minutes idling then drove it. Fell on its face under moderate acceleration in 2nd gear.
Took it to the dealer and could not get it to do it the whole way over after it did it initially. WOT onto interstate from ramp. WOT at highway speeds. Ran like a rapped ape.
By the time I got it there no one was able to look at it anyway. The service writer was a nice guy but he had no idea what I was talking about.
SM says possible causes for miss on accel are:
Plugs
Wires
Dirty fuel
Burned, warped, or pitted valves
Coils
Aside what you guys mentioned I guess we will have to see what the dealer can find. Probably nothing because it won't do it for them, I'm sure.
My gut tells me coil but then again my gut has been wrong before.
Not sure if you read my post but I had the exact same problem, and it was the injectors, one was not firing, have you checked ? make sure there are none loose
Have you tried going back to your stock tune?
This is stock tune, I have 172 T-stat and you can see the temp has not reached full operating temp yet at 200. This is when it does it. Has not yet done it cold or hot and has not thrown a code.
