RC HURST SHIFTER - WOT 3RD GEAR MISS
Prof said:
Stan, I defer to fstjack on this one...a lot depends on where you drive...AZ or Maine...but he recommends Mobile 1 Syn 15w50 for our engines...he thinks it costs a few horses, but is way better in protecting this hot bitch of an engine we love....
There are several here that use RP maybe they will chime in...
I agree..depends on the weather condidions. I use 15w-50 in summer / dyno tuning and track, and 5w-30w in winter; 10w-40 in average temps
-Red
Im in New York. But my truck never sees rain let alone that damn white sh!t.
I do realize that the 05 manual states 0w40 and 04 manuals states 10w30.
If some of you guys are running 15w50, then i would think that 10w40 is ok. Im curious if others are thinking the same thing.
I need to get any possible HP increases, even if they are minor, done soon. Track opens in 3 weeks. I must run a .7. My last MPH already tells me it will. But every little bit helps.
I checked just one plug. Gap was pointed at the ground. So you know that they're all F'd up. Doing that indexing tonight.
Thanks again...
Thanks again...
Are you going to do a pre/post indexing dyno run ?
Whats that? Indexing dyno run? Im an idiot....
I ran a 13.2 stock..ok just a flash.
Then I ran 12.91 with the addition of headers. Same 60ft
Now I have a full BB exhaust 3" cats. I will change all fluids with RP and index the plugs.
If I cant get a 12.7 im going to shoot myself....:(
As Roe recommended I went with Shell Rotella 15-40!!
With Mobil 1 I was adding a quart every change, I will let you know if it is the same with the rotella!!
No, was referring putting the truck on a dyno and seeing how much if any hp is gained by indexing the plugs.
Oh...
No probobly not. There was someone on the forum that did dyno before and after. I just saw it. Do a search. He gained 9hp at the rear wheels. Like a said earlier, I just pulled one plug to see the indexing. Damn thing was pointed at the ground.
I picked up my new plugs today. I guess they didnt understand that a Viper V10 has 10 cylinders. I only got eight plugs. Son of a b!tch.:mad:
I have indexed plugs on bikes. Both bikes(VMX12K & ZZR1200) that I did this too were unusually fast. Is there any correlation? Honestly, no clue. But I have dyno runs and times slips to prove they really were unusually fast.
So, what the hell, Ill try it on this motor.:D
