tank86
Okay here's how it works. Truck has like a 135amp alternator so it should fully charge even at idle.
Your voltages look okay until you turn on the A/C .. Could load from A/C compressor and/or alternator be causing belt slip ? Is electrical load causing slip or showing a defective alternator ? Or is the load showing bad wiring on the regulator or even alternator output ?
The alternator uses a voltage regulator that's built into the PCM !!
So since you have low voltage under a bigger load it's a pretty short list :
alternator bad
belt slipping
PCM weirding out
bad [ie corroded / cracked / shorted / etc ] wiring
Try an amp meter on the alternator + and see what you get under your A/C load and no-load. That might point you in the right direction. If you get really crazy you can monitor the voltage on the regulator+ input to the alternator. As it approaches system/battery voltage the alternator is at full output. If the reg voltage is high and the alt output is low then you've isolated the issue to bad alt or belt slip. Could end up being something almost unrelated like a bad A/C compressor causing belt slip.
--CC
I appreciate the feedback. I am just chasing a unicorn at this point it feels like. I just replaced the alternator, so hopefully it isn't that but I will check anyways.
Ok, so I ALWAYS have AC on. Well tonight as I was sitting at the drive thru I had it off with windows down. The fan kicked on (electric fan) to cool down and I noticed my voltage dropped as soon as I heard the fan kick on voltage plummeted. That would rule out AC compressor then and belt slip, correct? Would lead me to believe wiring or alt?
This is way over my head so I am just bouncing ideas.
