PLEASE READ FULLY:
as most you you know i scared shitless about doin this.
after talking to tony @ JTS and Mike @ snakepit performance this is goin to be my set up guy please chime in and let me know what you think and tony i will be in contact with you soon as get more money to pay for everything on shot.
1. STS turbo kit that will be tuned my marty @ krc (and i thank you for your support your a great guy to talk with and very helpful). my goal is to run 10psi and be at 800-850 wheel.and to have a truck running sucessfully on an STS.
engine stuff:
mopar comp coupe cam (i have already)
standard bore pistons (f it im buying the je's)
k1 rods, new rods and mains bearings,new gasket set (all from tony)
these parts im supplying to snakepit
now snakepits work and his game plan
clean up the bores and set motor up for 9 to 1 compression
do a 3 angle vavle job and re-deck motor and heads to match
NOW HERE ARE MY OPS FOR MY HEAD AND THIS IS WHERE I NEED HELP
he suggest that a do crowler springs and retainers wich will keep my top end togetter and will let me rev higher.
should i let them mess with this and should i let him drop the compression to 9to1 to boost the motor or does it sound like a good set up with no boom. thanks for the input and yes i already know the track record for the sts so let not murder the thread with that b/s.
engine stuff:
