Steering column shroud and adjustable pedals regulator (motor).
6speedquadcab
NorCal SF Bay Area
South Bay
Looking for a couple parts guys.
6 speed steering column shroud, and 6 speed adjustable pedals regulator (motor). I have an 06 truck but I've been told that the steering column shrouds are all the same color. If that really is the case, then any year column shroud will do. Same goes for the regulator.
Thanks.
Gentlemen, I would really appreciate a hand here. I need the steering column shroud for an 06 manual transmission truck. Please PM me if you have one. I believe the color is Slate gray for this year not black like the 04-05.
Column shrouds are not the same 04/05 is darker. I never found an 06 without having to buy entire column. Have an 05 in my truck right now
The part number for the shroud is 5GW81DX9AE. It is a paint to match trim piece. any dealer can order you that part and the paint to match it.
here are the notes for the pedal kit, you haven't been able to order the whole pedal kit for many years now.
IF MOTOR FAILURE ORDER KIT 68128177AA.
IF GEAR BOX FAILURE IN THE BRAKE OR
ACCELERATOR PEDAL ORDER 68079547AA, IN
THE CLUTCH PEDAL ORDER 68079548AA.
Just found one online! Thanks for your help though everyone. Perhaps you can help me with the adjustable pedals motor. Needs to be for the clutch pedal assembly.
Thanks for helping me find the shroud! As for the pedal assembly, I just need the motor. I have the pedal assembly already but it's missing the motor for the adjustable pedals.
