If you decide to plasti dip don't scuff the chrome first it sticks just fine, plus if you want to peel it of it will come off easy....I would recommend plasti dipping both sides...
Here's mine I did until I get them painted...BTW plasti dip is a spray on (plastic) that can be cleanly peeled off when not wanted...
Also I planed on replacing my chrome ram with a black and inferno viper emblem from Justin or tony....but after I plasti dipped it I thought it looked tits!!....I'm gunna order some flat dark gray and see if I like that better before painting them
painting them does not work well i have 2 sets that i ahve tried 2 different methods on both have chipped and look bad figure eventually i am just going to the mesh replacement
if properly prepped the paint will stick just fine...the entire surface must be scuffed up..the fine mesh on the 04-05 may be a lil tougher to do this..I would also use a primer designed for priming aluminum..
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
