I'm not trying to reopen any old wounds here but there is a guy on another forum looking for some help. I know these systems (for whatever reason) wouldn't build consistent boost and killed a few SRT10 engines. Anyway, here is his post:
Start-
Need help with an STS turbo system. After 5 months and way too much $$$ invested, my performance numbers and drivability are less then impressive. 2006 Reg cab with 6 speed.
Dyno -426.21 rwhp and 450.8 ft/lbs stock
489.06 rwhp and 557.45 ft/lbs turbo set-up
Note....turbo dyno is at a shop temp of 108.3 degrees.
STS rear mount Garrett 76 turbo, 5.5 psi (true 4.2 psi in crank case...yeah, that's it)
STS intercooler
170 thermo
69 lb injectors
SCT flash tunner with KRC's tuning (Marty)
Fully heat wrapped exauhst
It's a dog under 3200 RPM, lost tons of bottom end with the turbo
Strong 3200 to 5200, but not impressive
Sporadic hanging idle @ 1500 RPM
P0121 codes - Throttle body sensor error - frequency varries with changing tunes.
Falls flat after 5200
Turbo piping going to intake poor design...changes diameter, small to large to small to large.....possibly killing my manifold pressure
Can anybody help? Not happy after $14k invested.
Oh, and anybody that thinks an STS will blow up my motor, no way at 4.2 PSI and a conservitive ATF ratio(11.5 down to 10.5 as boost increase). You might have a point at 7 psi and 13+ to 1 ATF
***Marty @ KRC has been very good with trying to help, just looking for any other ideas*** -END OF HIS POST
Can anyone offer any help ?
Thanks!
Ronnie
Start-
STS intercooler
170 thermo
69 lb injectors
Thanks!
Ronnie
