moparracing
thanks for the breakdown on cost, tony...... too bad underground racing is on the east coast........
SilvrSRT10 said:mmmmtorque is doing that NA. Cam, heads and exhaust and throw in a VEC 3 to tune it all.
I think he's planning on installing his nitrous kit one of these days to increase the smile-o-meter.wont grow old said:that might be a good way to go too!!:rock: :burnout:
SilvrSRT10 said:I think he's planning on installing his nitrous kit one of these days to increase the smile-o-meter.
Paxton installed and tuned will cost about 10-11k depending on who does the workStinker said:I have asked over and over and over, and nobody seems to want to devulge how much a paxton install cost for 700hp:dontknow:
But with the Roe, many have told me having someone install it and the cost of the Roe is around $9-10,000
RedSrt007 said:Paxton installed and tuned will cost about 10-11k depending on who does the work
-Red
Rice Eater said:so bout 7 G's just to build up the engine to go over 750 horse. after that a turbo system or either SC+NOS combinaition will get you 1000+ to the wheels! I think you can score the ROE kit for 5 or 6 g's if you already have the VEC.......looks like I'm only about 13 G's away........someday:bebored:
Because it says VIPER on it.Stinker said:thats what I kinda figured, but from what I heard its been running around $15,000 and cant figure out why:dontknow:
Stinker said:Just for info
Pistons $1800
rods $1800
billet mains $700
machine work $1000
stock heads
turbo system $12,000
injectors $700
fuel rails $500
fuel pump $600
lines and fittings $500
boost controler $300
fuel managment vec III $1200
clutch $2000
engine assembly $1000
cam $400
push rods $200
end result $24,700
thats is also doing most of the work yourself which can be done, r and r the engine, clutch, fuel pump, lines, controller, injectors.
the engine machine work is extra you cant controll.
this is basically all I have withthe exception of the x-metal tb.
end result 750rwhp on pump, 1000rwhp on 116 octane.
but the power is also unlimited, with the Aem and heads, probably 1000rwhp on pump and 1300rwhp on 116.
things can be better, Aem instead of Vec, ported heads or strykers, and so on.
but this is the basics.
So low ball with you turning wrenches $25,000, with havin someone install $30,000
or you can opt for a single turbo kit and save$5000 but you would need to go with a larger turbo for similar results such as a 76mm.
Now those that have had a Roe installed end result? $10,000 for 620hp
those with a paxton? from what I have heard low ball $15,000 for 650+hp
nitrous headers and so on extra?
He ain't the only one. I'm putting down 535/566 (corrected) and it's awesome. :rock:SilvrSRT10 said:mmmmtorque is doing that NA. Cam, heads and exhaust and throw in a VEC 3 to tune it all.
ViperTruck2933 said:He ain't the only one. I'm putting down 535/566 (corrected) and it's awesome. :rock:
Stinker said:problem is rice that will about max ya out without spending a ton more money
with a turbo all ya got to do is up the boost:rock:
Rice Eater said:max out what the blower? hey i figure 750 HP to the wheels everyday w/ just the built motor, blower and smaller pulley will be good then at the track give it a little squirt squirt up to 250 shot.....plenty of power for Riceman!:elefant:
Stinker said:guy in texas has built bottom end, rods, pistons , billet mains, super high dollar ported heads, smaller pulleys , throttle body, intake, exhaust, and maxed out only made 696rwhp
besides, fords run the screw
Rice Eater said:696 w/ built motor and blower??:dontknow:
redice2 said:stinker i think you and i are the only ones that really like idea of twin turbos lol but i know i am a little on nuts side lol.. and i have talked to you so well what else is there to say lol
