He will ,, time zones are in effect on the otherside of the world upside down ..Well maybe he will post up!!!
Firearms are restricted thanks to Jacinda. No more MSSA etcSounds like a petting zoo lol ..
Are firearms illegal to own there or restricted ?
Do,your have Armadillo highways full of road kill lol
$59k NZi am still very interested in finding out what this build cost you, i know i asked previously and im sure you are absolutely in heaven being back behind the wheel of your freshly reforged Aragorn sword so i'll be patient.
Nice list!! And geez those lines are a common issue so with all that was done that's really not a bad deal all in all! Glad it's all working out so far$59k NZ
Motor is great. If you are in USA give John a ring at Southeast Performance in FL. He can build you one just like mine a lot cheaper if yours hasn't gone bang. You would also save on freight and customs charges and TAX. I could have saved money by not buying the Striker Heads but.......WTF
So the build list for me was:
New 2005 block
Callies Forged Rods
Mahle Forged Pistons
Boundary Billet Oil Pump
Mains Stud Kit
Head Stud Kit
Comp Cams Custom Grind
Slow Bleed Lifters
Hardened Pushrods
Striker Heads
Jesel Roller Rockers
Rocker Cover Spacers
Timing Chain
Cometic Head Gaskets
Apex Gasket Set
Mahle/Clevite Bearings (TriMetal)
Walbro 450l Pump
Deatchswerks 550cc Injectors (Bosch)
South Bend 800ft/lb clutch
New Slave Cylinder
Tuned by Torrie at Unleashed Tuning again
I think that's it
Just a stupid power steer return line leak when sitting in garage.
I can't fix at home I will send it in and get the 2 hoses replaced and the push lock BS removed.
View attachment 68670View attachment 68669
If you build before the pistons flake it would be a lot cheaper. The narrow ring lands on the OEM pistons, to get the emissions lower, are the only real problem. All depends on how extreme you want to go. The OEM conrods, especially the cracked cap rods are fine. The OEM lifters are High Bleed for emissions, the OEM pushrods flex, they were a cost cutting deal. Decent head work from John, a lot cheaper than Striker Heads. Gen4 heads maybe. A better cam. Probably $20k US. It all depends how far you need/want to go. I only changed fuel pump incase it struggles to keep up (it sounded marginal) The injector change because they may be needed and because the latest technology and 4 holes instead of 1 has to be an improvement over 20 year old injector technology. Fuel injection has come along way in 20 years. The oil pump....who cares by then I may as well, I was so far down the hole.Nice list!! And geez those lines are a common issue so with all that was done that's really not a bad deal all in all! Glad it's all working out so far
You already had the headers right? You just mummyfied them I think ... lol
Well that stinks , no wonder the invasive species are taking overFirearms are restricted thanks to Jacinda. No more MSSA etc
You have to have licence too
Push lock ?$59k NZ
New 2005 block
Callies Forged Rods
Mains Stud Kit
Head Stud Kit
Slow Bleed Lifters
Hardened Pushrods
Striker Heads
Timing Chain
Apex Gasket Set
Walbro 450l Pump
New Slave Cylinder
I think that's it
I have the same issue only less space lolThis might give you a clue why I do do much on the truck at home
View attachment 68675View attachment 68676View attachment 68677
I get it now ! Tight garages stink .. thats a up hill driveway launch pad .. you know , you should get @Wifey to come take care of all that growth in the yard ,, I know she loves to kill weeds ..This might give you a clue why I do do much on the truck at home
I have a driveway and jackask HOA THAT HAS A STUPID RULE YOU CANT WORK ON VEHICLES ON YOUR OWN DRIVEWAY ! I do what I can when I can and try to be invisible to neighbor grown up tattle tales ... ive been sent letters and threatened with fines about half a dozen times for their idiot rules .. The premadonna president of the HOA is a keyboard lawyer that likes to throughnout Statues she doesnt even understand lol Statue - §6kissmyask#66-666 ..I have the same issue only less space lol
Have you been drinking again?I have a driveway and jackask HOA THAT HAS A STUPID RULE YOU CANT WORK ON VEHICLES ON YOUR OWN DRIVEWAY ! Imdomwhat I can when I can and try to be invisible to neighbor grown up tattle tales ... ive been sent letters and threatened with fines about half a dozen times for their idiot rules .. The premadonna president of the HOA ismamkeyboard lawyer that likes to throughnout Statues she doesnt even understand lol Statue - §6kissmyask#66-666 ..
Wow, so aboot 48k my CaNUCKistant dollars. i guess i should start savin.$59k NZ
New 2005 block
Callies Forged Rods
Mains Stud Kit
Head Stud Kit
Slow Bleed Lifters
Hardened Pushrods
Striker Heads
Timing Chain
Apex Gasket Set
Walbro 450l Pump
New Slave Cylinder
I think that's it
The biggest saving is having the engine in one piece before you start.Wow, so aboot 48k my CaNUCKistant dollars. i guess i should start savin.
Just asking for a friend![]()
I dont drink but my ipad types in tongues lolHave you been drinking again?
Probably not NEVR DULL but it really has a crystal clear shine! Maybe it's KIWI juice!What do you use to shine it up like that with ?
It has to he Kiwi juice lolProbably not NEVR DULL but it really has a crystal clear shine! Maybe it's KIWI juice!
