This is why you should run a Catch Can.
Discussion in 'General Discussion' started by Tincup, Mar 14, 2020.
Car Parts
  1. Tincup
    Tincup Full Access Member
    156
    9
    Feb 3, 2014
    MA.
    I was cleaning my intake in preparation for painting and this is what I found. The inside of the intake was pretty dirty with baked on oil, and this is what the injectors looked like (before and after cleaning). Keep in mind my motor only has 30k miles on it.
    rottenronnie likes this.
  2. rottenronnie
    3,021
    294
    Jul 4, 2006
    Calgary, Alberta
    I cleaned the oil out my "Accordion" Intake-Tube for the last time because after installing a catch-can, there wasn't any there ever again.
  3. AMS3
    AMS3 Active Member
    206
    55
    Aug 8, 2019
    Savannah Ga
    Just had mine installed this past Saturday.
    Ronnie, I have a question. I also had my BBK TB installed, and I've noticed that the tranny doesn't disengage any more when coming to a stop. My engine is surging with the foot on the brake. If I pop it in neutral, it'll drop to the normal RPM in idle. What's the problem here?
  4. rottenronnie
    3,021
    294
    Jul 4, 2006
    Calgary, Alberta
    Not that anyone should have been under there to install a throttle body (unless they thought you said Valve Body) :) but make sure the return spring is installed (Driver's side) on the outside of the trans.
    Also your kick-down linkage adjustment is touchy.
    It has to move as soon as your throttle does. Not before (so not under tension), not after.
    Another touch adjustment (can be) the BBK curb-idle adjustment. If it is open too far, or not far enough, it will go to war with the A.I.C. motor to try to keep the idle level. It is a trial ad error adjustment and it is also very touch. SMALL adjustments either way will/can make a difference.
    Apparently all the schools are closed here in Calgary Alberta until September and we are under state of emergency so I better stick my head outside and shine up the 50 cal. ;)
    MGVIPERTRUCK, Slitherbeast and AMS3 like this.
  5. rottenronnie
    3,021
    294
    Jul 4, 2006
    Calgary, Alberta
    Saw this yesterday: A picture of Forrest Gump saying: "And just like that, wiping your ass is more important than climate change".
    AMS3 likes this.
  6. rottenronnie
    3,021
    294
    Jul 4, 2006
    Calgary, Alberta
    Apparently the "Y" on my keyboard isn't awake yet.
    So scare....
  7. AMS3
    AMS3 Active Member
    206
    55
    Aug 8, 2019
    Savannah Ga
    Thanks for the tip. I'll have to look at this when I get time. It does have significant more pep when hitting the throttle, I noticed. :). Also, my tranny seems to shift better, other than the surge I mentioned, but that's only when stopped. A buddy of mine told me that it usually takes about 100 miles for the computer to adjust to the new larger intake of air. Is that true?
  8. rottenronnie
    3,021
    294
    Jul 4, 2006
    Calgary, Alberta
    Ours are speed density systems (fixed calculations) that rely on air pressure (barometric) instead of air FLOW (like a Mass Air Flow system does).
    All else being equal (no leaks) you will need to adjust the curb-idle on that BBK to prevent idle hunting.
    AMS3 likes this.
  9. AMS3
    AMS3 Active Member
    206
    55
    Aug 8, 2019
    Savannah Ga
    Since I'm not the one who installed the TB, where is the curb-idle adjustment screw located?
  10. rottenronnie
    3,021
    294
    Jul 4, 2006
    Calgary, Alberta
    Likely a black threaded screw that has some Blue Loctite on the threads.
    You will see it.
  11. rottenronnie
    3,021
    294
    Jul 4, 2006
    Calgary, Alberta
    With the engine running, try a 1/4 turn clockwise and see if it gets better or worse. If it gets worse, go back the other way. Like I said, trial and error.
    This is assuming there isn't something else that is loose and/or sucking air in. Have a look around and make sure they (for example) hooked up the small rubber hose (bottom-center) on the throttle body, the AIR motor (passenger side is tight), etc.
    Good luck
    AMS3 likes this.
  12. AMS3
    AMS3 Active Member
    206
    55
    Aug 8, 2019
    Savannah Ga
    Update: She idled perfectly at stop lights this morning going to work. I'm not going to touch anything, let it break in. If it continues the surge, I'll play with the adjustments. I will however, check for leaks, etc. like you mentioned.
    Kiwi SRT10 likes this.
