JeffBoyette
I'm installing a Roe Throttle body and it says I have to grind the threads off the original throttle plate screws from the shaft. I have no dremel. Is this step necessary?
YES! otherwise you risk breaking off the screw inside the shaft. The screw ends are smashed to prevent them from backing out
I think he means after the shaft was removed it had to be ground to go back into the X-metal.
Use a die grinder to knock the mushroomed section off.
