1.74 with lower then normal launch RPM. I'll be needing a new set soon.
I am mostly blaming my spinning on my 390's being old and have over 40 runs on them. Need to get some new ones but can't right now Mine still hooked like a MF on the 1-2 shift:rock: :burnout:SlicksMH said:I have somebody running the 390's in a dodge car right now with twin turbos, he took them out for a test last week and he told me he could not brake them lose. Soon he will be going to the track to make a record run. :burnout: Will see what happen.
SlicksMH
TNVIPER said:I cut a 1.72 my first time with M&H DRs...I bet I can do better..
tsmith3 said:1.74 with lower then normal launch RPM. I'll be needing a new set soon.
FerrariTruck said:John MH can you pm me a price on 2 tires. I need a set of front runners. I would prefer a 28" tall tire if avail but I only see 27" availble in a 15" rim
wyoramsrt-10 said:I am mostly blaming my spinning on my 390's being old and have over 40 runs on them. Need to get some new ones but can't right now Mine still hooked like a MF on the 1-2 shift:rock: :burnout:
SlicksMH said:That is the tallest we have the 27"er. Is that what you want.
SlicksMH
I cant remember his screen name right now but he had the supercharged Paxton in the Denver area(the guy I bought them from). They will be 3 years old after this season.SlicksMH said:How old are they ?
SlicksMH
FerrariTruck said:well i'm not sure really...do you think that tire is tall enough to work for our trucks or do you think i should look into the 28" that moroso sells called ds2?
SlicksMH said:How wide is the rim 15"x ?
SlicksMH
FerrariTruck said:well i havent bought it yet either but that was another of my questions. do you think the front runners you sell will work on a 15x6 or is a 15x4 or 15x5 max they can do?
SlicksMH said:15x5 would be find.
FerrariTruck said:ok good heres the rims i'm looking at getting. I will be running this on 70 monte carlo and on the truck as well. thats kinda why i want the 27" but i know the 28" would be much better for the truck. do you think the tire size will matter much? as far looks, weight capacity, traction for a 5100lb truck?
my main conerns are them being safe for the heavy truck and light
rottenronnie said:1.807 60 with a dead idle launch (auto) with M&H Drag Radials and Eagle Alloys (rear only). No Caltracs...
Could you provide a price (p.m.?) on the new 390s? Mine won't bite off the line anymore...they are almost down to the wear-bars, so I think that may be the problem...
Ronnie
