Timing chain
BLWNSRT
Member
Im trying to find a part number for a timing chain. The factory one 5086533AD is $616.44 I've only got 18000km on my engine.
For those who have done an engine build what brand/part # did you go with?
Is the 8.0L the same chain?
we run the cloyes but it has to be modified a little to work on the gen III , but if you wnt the oem, it can be had for less also
That's the 9-3152A cloyes what kind of modifications are needed. Also if you have a chance can you find out for me what he factory chain is worth. Some of the stuff i get from the dealer has been matched to US prices but some not.
I also seem to keep finding the Cloyes part number 9-135 for 2005 viper car 8.3L raised cam.
be sweet if there was a gear drive set up for the Viper engines
:rock: :rock: :rock: :elefant: :elefant: :elefant: :burnout: :burnout: :burnout:
Isn't there a part # for the oneI have on the one on the build sheet Jeff? it's a double roller Cloyes chain and gear set Im pretty sure!
No you got the factory one same part number same price that I listed. I'm looking at the sheet right now :pcguru:
Is the factory one a double roller? If it's showing the factory o e on my build sheet I will be making a phone call tomorrow!!!!!
Guess you willbe making a :call: tomorrow :fight:
Yes, it is a double roller. Made in Italy...(Lambo roots :))
Yellow venom said:
Does Cloyes make it Ron?
MADE IN ITALY
Just like any other double roller- Stretches like a bastard almost immediately (even with moderate spring pressures) :(
I have a brand new Mopar in the box with the gears as well that I won't be using. Make me an offer. I can ck the p/n's in a bit.
