Tires!!
Psycho Mythic
Tifton, Georgia
So whats the best tires to get for these beastly trucks? I kinda wanna go 325/40R22 rear and 305/40R22 front :burnout: , but i really like the look of the BFG G-Force tires, what do you guys think:dontknow: ?
The BFGs are probably the best if your main concern is traction (dry weather). I talked with several members here that had them and the 2 main complaints were noise and bad wet weather handling.
I have Continentals on my truck and they ride so much better then the stock tires. I can also get a better launch with them.
I don't think there's a. Real cure for wet traction with these trucks except not using first gear, plus I try not to drive this thing in the rain anyway. And as loud as my truck, I believe the only noise I will hear from my tires is when their screaming :D
you're better off sticking to one size. you dont want to have one set smaller than the other since these vehicle are equipped with 4 wheel abs. i have the cont 305-40-22 and i have to say that they are a great tire
I'm running the BFG KDWs and don't know what noise issues folks are referring to. I've had 3 brands on my truck - stock Pirellis, Yoko Paradas, and these KDWs.
None had great wet weather traction, but that's not much of a surprise either. The Yokos were probably the best at that, but the truck was still a handful in the rain. The stockers were noisy, so much so that I replaced them with the Yokos on my trip home from purchasing the truck at 8000 miles.
The BFGs stick where the other two did not, both straight line and in the twisties. With the F&R Hotchkis bars I put on that help keep the tires planted, it sticks pretty damn good - still working on finding that limit. :)
My $0.02 is that if cost isn't your primary concern, go with them.
thanks alot man, I've heard alot of good things about these tires, gonna look around and see if I can find a promo code ;)
I have them also, Very good in rain and just about all over. they do dig very good when you stomp on it.
Psycho Mythic said:
Man your truck looks great! What lowering kit do you have?
The Sig says "Stinker's 2/4 drop kit" but that looks lower than that. Real nice! :D
Yeah, i guess i should start reading those :eek: . I just put stinkers springs up front and it sits about like that:rock:
I just put BFG KDWs (305/40/22) on my 05 & I have nothing but good things to say so far. Have no idea what noise issues some say they were having. Yes the KDWs were a little pricey but we are drivin a BRICK for petes sake. If you consider the cost of this truck, how you drive it, etc, try not to put the cheapest rubber on it you can, remember, that tire is the only connection between you & the road
I put the BFG's on the in July and they stick to the road in the corners. I have road raced them twice.They are better than the stockers.
Anti-sway bars - I did a writeup recently. I don't have a link handy, but suspect they'll come up in a search by their name.
FlyingLow said:
I have never heard of those. What are they?
Bfg's are the way to go if you have the money. They handle way better than any other tire, I cut a 1.7 60' with them. I do notice more road noise, almost sounds like you driving with an all terrain tire on it...
some people here in Belgium and Holland go for the Conti's , but instead of 40 they go for 45 in height...
BFG's are BF Goodridge , right ? :dontknow:
Psycho Mythic said:
Yes sir! I can get the nitto 420s for $680 mounted and balanced. Are those good tires?
got nittos on my sled and have no complaints ,,i went with the 45 though seems to improve daily driving too ,,plus i discovered you will get almost no curb rash on your rims cause they a a tad high than the 40,s ,,
