TORQUE # FOR FACTORY HEADERS
SANCHOBA
TEXAS A&M DAD
INGLESIDE,TX.
installing my jet-hot coated factory headers (yes, thats what they are:D )...have one side installed with new stainless hardware, but need to know how tight:dontknow: also tightening from center towards the ends is correct,right?
that might work out to be the same... dont know for sure.. I got that out of the manual.. anyone know if 200 in lbs is equal to 17 ft lbs???
200/12=16.67 ftlbs... close enough
While we're on this subject , do you need any coating on the bolts like antisieze? Is the dealer only place to get new gaskets?.. Im having my manifolds coated and am reinstalling them
Steve
and that was pretty freakin easy math...
Lots of folks get confused with simple stuff my self included. Just use dimensional analysis where you assign dimensions to the numbers which multiply and cancel just like real numbers. So:
[200in.lb]x [1ft/12in ] = 16.67 lb.ft. See how the inches cancel and your left with lb.ft?
Pretty boring Chit huh? Yawn........
SANCHOBA said:
ha! never seen an inch pound torque wrench!:confused:
TaDa!
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2696
http://www.sears.com/sr/javasr/prod...OOL&subcat=Torque+Wrenches&BV_UseBVCookie=Yes
http://buy1.snapon.com/catalog/item...9&group_ID=953&store=snapon-store&dir=catalog
The Mac Tools site was all jacked up at the time of this post, but I'm sure they have them too.
Steve
1. Yes. Anti-seize is a good idea on the header/manifold bolts.
2. Every time your pull the headers/manifolds, replace the gaskets. TMC or Dragon can get you the hook-up.
beat me to it! thought that was obvious:D
I just tightened mine down and drove!!!
all done! found some 3" stainless bolts at lowes (5/16" x 18). the toughest part of course is getting the old rusted sh!t off. also put some stainless hardware where they couple to the mids.removing the wheel liners is a must.... was done in my garage and all i used was a jack and stands!:rock:
U putting those alum heat shields back on
Be careful using bolts from the local home center. They are not normally of sufficient quality to be used in automotive service. I believe you want grade 8 bolts.
