seethrough
Member
Does anyone know the voltage range of the Throttle Position Sensor on our trucks. I am looking for idle voltage and WOT voltage. Thanks.
From another thread.It needs to be .68v or less. If it is higher , then you have to remove the TPS and twist the shaft . like the picture. reinstall TPS and check voltage . twist it the right way . disconnect battery so the ECM can relearn the corrected voltage. Don't twist to far !! or the TPS would be able to read throttle position and you will end up with a stumble. Mine still functioned correctly down to .47 volts
Thanks caveman. Now I just need to verify that the WOT voltage is in the 5V range.
My idle fluctuates 2-300 rpm.
Like, up down up down up down.
Is that caused by this voltage stuff? How do I measure what the voltage is supposed to be?
