At WOT in 1st gear, the computer should command the 1-2 shift by spiking the governor pressure through an 800 millisecond electrical pulse on the govenor solenoid. It can be measured by reading the electrical signal going to the solendoid or by having a fast reacting fluid pressure gauge screwed into the govenor solenoid port. If the spike is occuring but it is still not shifting, there likely is an issue with dirt (old tranny friction material) in the valvebody or a bad seal around the solenoid bracket area. There may also be an internal fluid leak somewhere that is preventing the govenor pressure from fully acting on the 1-2 shift valve when line pressure and detent pressure are maxxed out, or the valve body could be warped and not mating up properly to the transmission case.
