VIPER-INJECTED
Just bored :bebored: So here ya go...
This is just for ppl that don't know what to do and would like to work on their own truck. Sorry for the pics(iPhone).
I was not going to get my Nikon dirty for these pics. Just helping out to keep these trucks on the road:rock:
As for what type of fluids, I have noticed here everyone has their own opinion. Use the search button and you will see...
Note: If you do not have access to a vehicle lift, be sure vehicle is level on jack stands. Do not just lift the front end to get under vehicle.
If vehicle is not level, you will not put the correct amount of fluid in trans/rear diff. This will cause damage if fluid levels are to low causing lack of lubrication.
You can also use a shorter extension (I also used a 1' inch extension.)
The liquid gasket is used to the drain and fill bolts before you go to reinstall them.
Don't drench the bolts with /lightly coat threads.
You can also use Teflon tape whatever your personal preference is.
Drain bolt located on passenger side of transmission
Fill bolt located on drivers side of transmission
Fill trans until fluid starts to slowly drain back out of fill hole (same goes for the rear diff)
trans took exactly 3.5 quarts of fluid
Don't forget limited slip additive for the rear diff- factory Mopar LSD friction modifier 4oz bottle p/n- 04318060AB
