FerrariTruck
the flywheel being warped is bull shit. the clutch pucks wearing on the outer edges is not abnormal.
Sharpimage said:Christ... Alright, get this. So i went to the transmission shop today and
the guy said he never heard of a Tremec......He was extremely helpful
and very careful about everything he did regarding my vehicle but he
doesn't really know why it is acting the way it is. I plan to go back over
later today and help him take out the transmission so we can inspect
all the internals.
IF the flywheel looks fine, the clutch looks fine, and my
slave doesn't show any signs of leakage then i am prepared to buy a new
master cylinder, replace the flywheel insert, replace the clutch disk, and
bleed the system again with his help. I definitely will be taking pictures of
all of this so you folks can see the stuff yourself..
I'm having second opinions on this guys ability but he's been in business
for 25 years.. That has to stand for something... But i don't really have
a choice, only other places around me are Aamco or little import shops
for ricers.![]()
DevilDawg3097 said:Ok maybe I should of said MOST shops in Bigger cities have heard or worked on t56,![]()
:marchmellow: but to them a trans is a trans. Well at least he is gonna let you watch I know the dealer would not of let you. But I hope you get it.
Honestly with your mods I would just go with a stocker again work even better with the slave uprgrade. Sean has a better then the stocker for the same price I beleive he said it can even handle up to 800hp, but t=dont quote me It has been a while since I asked about it.Sharpimage said:Thanks man![]()
On another note, is it possible/would i want to just replace the clutch disk
and not the pressure plate? or is that a bad idea?:dontknow:
EDIT: I just got off the phone with Larry @ Centerforce and he said that they don't stell the Clutch plate's alone so if i want a new clutch i need to buy
the pressure plate and disc together.:\ Anyone have a new clutch set they're trying to sell![]()
DevilDawg3097 said:Honestly with your mods I would just go with a stocker again work even better with the slave uprgrade. Sean has a better then the stocker for the same price I beleive he said it can even handle up to 800hp, but t=dont quote me It has been a while since I asked about it.
I would say yes if it where a true dual disk like the ones I put in our semis then yes but not with this one. how many miles are on this one?Sharpimage said:Yeah, i had the stock clutch go up at 5k? or earlier? I'm not sure but
it was slipping pretty bad.. I just find it real hard to believe that my
clutch might actually be bad. What exactly happens if the clutch doesn't
seat properly?
EDIT: Also, would a improperly worn clutch give me a weird engagement point? Now that i think about it the clutch has always engaged at that point.. Even at the PA GTG i went to over at Riff's place..
DevilDawg3097 said:I would say yes if it where a true dual disk like the ones I put in our semis then yes but not with this one. how many miles are on this one?
well do tell what brand of clutch is going 50k miles while drag racin' it ??DevilDawg3097 said:they went with a different brand and where getting 45-50k while still trackin it.
71dusterjon said:you know its probably going to end up being something small and stupid.
they dont track every weekend but they have been getting 50k out of the spec II and III this is what I think I am going with next. But for the guys who arent FI the one clutch sean told me about is very good and works with the stock slave if you havent changed it. It is better then the stocker and has good clmping force. But again just give him a buzz he can help alot more then I can.moparracing said:well do tell what brand of clutch is going 50k miles while drag racin' it ??![]()
after much thinking bud, an since it worked before, I think you will end up with a master cylinder probSharpimage said:Oh i'm certain it will be.. I bought a $15 pilot bushing for a reason![]()
But i feel it's the hydraulics more importantly.. So i'm not sure.
Stinker said:after much thinking bud, an since it worked before, I think you will end up with a master cylinder prob
FerrariTruck said:viper tech guy is an idiot. please tell me how a flywheel will cause a soft pedal.....
FerrariTruck said:like i said before, our clutches tend to wear like that. It's just be cause of the way the clamping force of the clutch is distributed. my stock clutch with 45k miles was worn exactly like that and my flywheel was heatcracked to shit and it still did not slip and was able to powershift it. the reason i finally decided to do it was cause i started to hear a squeaking from a metal rivot on the disc starting to wear into the flywheel.
as far as changing the master, you dont need to unbolt it.
just disconnect the connector
remove rod of clutch pedal
twist the master cylinder to the right and it will come out.
