VENOMOUS1 RACING
It up and running, I took it for a ride around town. All seams well. It was cracked outside of the seal, not the part that goes in the engine, where the mounting bracket meets the actual sensor.
Gotcha, that itself could have changed the gap the PCM needs to see from cam sensor. You can disconnect battery for about 10 minutes and touch cables together to fully drain battery and reset PCM. Good to hear the beast is back!
