Truck stalls when backing up?
Annu Kumar
Berkeley, Ca
Guys has this ever happened to you in a Qc. Put it in reverse turning the steering wheel and the engine shuts off!! This has happened atleast 3 times in the last month.
This has not happened to me either. When the engine stalls is the steering wheel tuned all the way in either direction? Will it stall if you only have it turned half way?
Brad
me eather when im idling it sounds like my rpm's drop a lil sometimes but goes back up quickly never staling
mine wouldnt move until i hit alteast half throttle when the engine was cold . once warmed up it was fine . took it in to the dealer , they inspected the tranny and found metal chunks and shavings , they replaced the parts under warranty , no more problem . Maybe this has some thing to do with it ?
Yes this has happened on my truck several times. I notice that you have a 06 QC the same as mine and also a stage 2 PCM (mine is from boomer) it happens when you have low revs in reverse. I will be taking the PCM out this week for towing and will see if that is the problem. My truck has 1,100mile on it.
Contact boomer and get some of the Billet muffler Bearings..........Thay are Di Beeesst :D :rock: You crack me up Brady LOLOLOL
YES!!!! I found someone that has the same problem as me. I mean its not a Big Deal, But I was on a Date with the Brand new Ram srt 10 And the shit stalls and I'm like This is normal Baby. But anyways The truck is aslo a good Chick magnet.
:confused: .........................:rofl:
