UNKNOWN NOISE...NEED HELP!!
unknown noise
It sounds like the throw out bearing in your clutch. I had one go out on me on my work truck.It did the same thing.
I may be on my way to Eddies house in alabama but most def you can call bud,
I wouldnt worry too much on the whining unless it happens to come back , personally the very first thing I would do is remove the serpentine belt, check all the pullies, spin and feel each one, that way all the rotating mass on the front of the engine is taken care of .
On it, thanx for the time.
Stinker said:
long as ya under warranty bud
only bad thing about that is, you will get the same POS oil lines, the 3 "Viper Tech" i talked to never heard of an updated by-pass valve.
i would vote for gettin Stinker's oil lines, no matter what.
get in touch with Kevin @ EED & see if your engine needs the update
go with the Viper oil filter (05037836AA)
:rock: :burnout: :rock: :burnout: :rock: :burnout:
oh and a set of Stinker's P/S lines & that will take care of any line issues on the trucks.
a set of poly bushins to go with the P/S lines is an excellent upgrade & with a set of Cal-Tracs, she will be 100% better handlein.
man moddin is great:rock: :rock: :rock: :rock: :burnout: :burnout: :burnout: :burnout:
Just gettin back to work on Monday from vacation....just in time right:D what is eed?
