Vacuum leak
Discussion in 'General Discussion' started by VIPR PWR, Dec 27, 2019.
Car Parts
  1. VIPR PWR
    VIPR PWR Full Access Member
    4,993
    272
    Jun 12, 2007
    FL
    Opened the hood this morning and found a vacuum leak .. did doge use some kind of cheap ass rubber hoses on these trucks ... I’ve had the hose to the cruise control leak , the hose to the air cleaner leak and now the hose out of the top of th drivers side valve cover ,oil lines and power steering .
    see pic of this leak below ! I was wondering if that’s the reason my BBK might be or not be sticking after 40000 plus miles since installed .. it definitely has caused the idle to raise and dro back down when I hold my finger over it ...
    where can I get a preformed replacement besides the stealership ?
    Kiwi SRT10 likes this.
  2. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    I've replaced virtually all of the oem vacuum hoses over the past 15 years. None of the original molded hoses remain. Conventional (decent quality) hose can be used with some creative routing to replace any need for molded hoses.
  3. VIPR PWR
    4,993
    272
    Jun 12, 2007
    FL
    yes , and if I’m not very creative on those sharp bends I kink the hose a bit lol like on the one that runs to the K&N .. but a 90 degree oh my hahahaha . Not much to work with there ..
    maybe I should install the catch can I’ve had for about 15 years .
    I’ve been trying my hand at buying and selling crypto currencies to pay for some things .. it will take 1152 years at the rate it pays just to buy the hose lol
    Kiwi SRT10 and Wifey like this.
  4. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    You can always find a 45 or a 90 degree fitting if you need them.
    Catch cans.
  5. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    +1 for a (sealed) catch can.
  6. VIPR PWR
    4,993
    272
    Jun 12, 2007
    FL
  7. VIPR PWR
    4,993
    272
    Jun 12, 2007
    FL
    The one in the pic looks very similar to the one I have ... just need to find it in my piled up junk room.
    jmerformance catch can I beleive
  8. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    JMB used an air filter on top of his. At least the one I had from him did.
    The problem was it smoked like an old 440 with cork valve cover gaskets, so I sold it and bought a large sealed type that doesn't smoke at all.
  9. AMS3
    AMS3 Well-Known Member
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    What brand catch can do you recommend?
  10. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Kiwi SRT10, AMS3 and TrailMix like this.
  11. VIPR PWR
    4,993
    272
    Jun 12, 2007
    FL
    Yes I beleive mine has a filter on it ... of course I haven’t seen it for years . Need to find it and organize some
  12. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    It depends what you expect from it. There is a considerable difference in price.
  13. Yellow Fever #319
    Yellow Fever #319 New Member
    6
    3
    Dec 10, 2017
    Tampa, Florida
    Question related to this - in your photo, I see the indent in the rubber hose exiting the valve cover. To the left of that hose, there are hoses joined by a plastic T-valve. Does anyone know what those hoses are for or where they lead from/to?
    I took my intake manifold and valve covers off to get them powdercoated. Now, I'm putting them back together, and the last thing I couldn't figure out is where to attach the hose that goes from that plastic T-valve and dives under the intake manifold. Was it attached to the underside of the intake manifold, where there is a short tube extension entering the manifold? Thanks in advance for any help ya'll can give!
  14. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    If you have a mirror, you can find/see the metal fitting that pokes straight down from the underside of the intake manifold. It is easily seen with the throttle body removed.
    If that doesn't make sense, it is because I am under the influence of confusion.
    But I think that's what you're asking about.
    Kiwi SRT10 and AMS3 like this.
  15. Wifey
    Wifey Well-Known Member
    23,065
    337
    May 18, 2006
    Taxifornia
    I understood that completely so he should too!!
    AMS3 likes this.
  16. Yellow Fever #319
    6
    3
    Dec 10, 2017
    Tampa, Florida
    Awesome, thanks, that's the only place I could find to attach it that seemed to make sense
  17. Kiwi SRT10
    Kiwi SRT10 Well-Known Member Supporting Member
    967
    1,000
    Dec 16, 2019
    New Zealand
    Go with the catch can;)
    VIPR PWR and AMS3 like this.
