Rickspeed
Looking for a set of 4.10 gears, Thanks.
Begood said:I have a set complete with carrier. But I think the shipping would be quite expensive.
Bill.
DevilDawg3097 said:between 25-40 bucks ups
TNVIPER said:I dont think you will like the 4.10 over the 4.56...
Rickspeed said:Why is that?
Higher top end speed, lower rpms while cruising on highway doing about 75-80. I think it will help at the track when I start running 17" rims with drag radials.TNVIPER said:What are you wanting to accomplish with them??..
Rickspeed said:Higher top end speed, lower rpms while cruising on highway doing about 75-80. I think it will help at the track when I start running 17" rims with drag radials.
All the more reason to go 4.10:aetsch: well see in a week or two if I go 3.92 or 3.73. Rule of thumb for the dumb:elefant: the higher the HP the lower the gear i.e 4.10 to 3.XX the lower the hp ie the higher the gear 3.73 to 4.88. It should make for better highway also Ill take you 4.56's and higher at top end anyday of the week with my 4.10s and that s the fact jack:elefant: :itsme: Plus He is roe'd nowTNVIPER said:Probably wont help with top speed and may make it feel heavy on the street......before you spend a ton of $$$$ check with someone who has done this.....been a lot of discussion in the past but I cant remember anyone who has made the swap..........
..I do know that most of the 04 RC owners that changed to 4.56 liked them much better than the 4.10..
DevilDawg3097 said:All the more reason to go 4.10:aetsch: well see in a week or two if I go 3.92 or 3.73. Rule of thumb for the dumb:elefant: the higher the HP the lower the gear i.e 4.10 to 3.XX the lower the hp ie the higher the gear 3.73 to 4.88. It should make for better highway also Ill take you 4.56's and higher at top end anyday of the week with my 4.10s and that s the fact jack:elefant: :itsme: Plus He is roe'd now
04rcmoneypit said:I have a set also if you can't come up with any
stanssrt10 said:trade u 4.10 for 4.56 straight up.got a set with 1800 miles on them
Ring, pinion, carrier. About 24k, no problems with them. Let me dig them out and I'll let you know.Rickspeed said:How many miles on them? Include carriers? Price shipped to 07036, NJ? Thanks.
