Rickspeed
04rcmoneypit said:Ring, pinion, carrier. About 24k, no problems with them. Let me dig them out and I'll let you know.
Ok, keep me posted. Thanks
Hucksrt10 said:I think the QC would benefit with the 4.10s would drop the highway rpm by 500 at 70 and would stay in first alittle longer. The autos have only 4 gears and the RCs have 6 . the RC is a slug in 6th with 4.10 much better with the 4.56.
TNVIPER said:Rick, make sure to do a thread on the 4.10s once installed.....I know a few would be interested...try to make some track runs before & after.....and you should resolve the issues you are having with the Roe before changing the rear..
Rickspeed said:The Roe was fine, besides maybe running a bit rich. 10.0-10.5 on the wideband. Problem was I was spinning all of first and part of 2nd. My 60' times were between 2.100-2.500, and that was with 22psi in the rear tires.
DevilDawg3097 said:The 4.56's where more than likely a replacement for the 4.10's because of the tow option.:aetsch:
Do you want me to get a shipping quote? Or are you going to swap with the guy that has the 4.56s? And mine have about 3000 miles on them.Rickspeed said:I am serious, please get me a quote asap. Use 07036 zip code for quote. Thanks.
Begood said:Do you want me to get a shipping quote? Or are you going to swap with the guy that has the 4.56s? And mine have about 3000 miles on them.
Bill.
Rickspeed said:Please get me a quote, I'm ready to move on this I can't wait. First person to give me a total price shipped for gears, ring, pinion, and carrier gets my money. Thanks.
JTS VENOM PERFORMANCE said:going to a 4.10 is something I have begged folks to do , it should increase the mileage, but will have some minimal effect on times
:dontknow: :dontknow: :dontknow: :dontknow: :dontknow: :dontknow: :dontknow: but the truth of the matter is more gear less spin such as 5.38
less gear more spin such as 3.73:dontknow: :dontknow: :dontknow: :dontknow: :dontknow: :dontknow:
you may gain some top end, it may help a bit on take off as you dont or wont spin right off , but the power is now stretched out a bit , so feathering the throttle is gonna take practice,
basically all you are doing is moving the power band, jsut on the asphalt instead of the rpm range.
so instead of things whacking right off, it will move out the ashpalt a few yards.
it will be interesting to see your results:rock:
kyle's srt10 said:UH...... $100 Shipped:dontknow:
not reallyZCx said:ain't that bass ackwards?????:itsme: :dontknow:
JTS VENOM PERFORMANCE said:not really
yes and no,ZCx said:splain lucy:dontknow:
gears multiply torque. the bigger the number, the more torque, easier to spin the tires, correct????:dontknow: :dontknow:
JTS VENOM PERFORMANCE said:yes and no,
the higher gear ie 4.88 will spin more if you are dropping hte clutch yes, but will hook up easier via it putting more hp to the ground per rpm
