in short, and in which most will disputZCx said:so
a harder launch with high gears
a softer launch with lower gears
:dontknow: :rock: :burnout:
with higher ratio such as 4.56 up you are using the hp to move the vehicle, thus also less spin, but more hp is spinning the tires then trq
with lower you are using trq more to move the vehicle, trq creates more spin per revolution,
trq is harder on take offs then hp, more trq more spin, more hp less spin
common misconception is going to lower gears to creat less spin
now that being said, the 4.10 may be the perfect combination on the QC, it has yet to be seen.every application reacts diffferently to each mod
