AWDisuzu
you might want to investigate why you're not running 14.2@98 (ish). you might have a cylinder or 2 not firing.
best of luck!
~mike~
best of luck!
~mike~
Deibs said:
Prof said:There are lots of us that have pursued low numbers but only a few with the dedication to achieve the goals we set...the thrill of the pursuit is invigorating, expensive and often frustrating.
Getting into the 11's is a very difficult task, 10's are impossible for all but one or two of us. Set your goals realistically...relatively stock trucks low 13's to high 12's.
Boosted trucks mid 12's to high 11's. Sprayed trucks mid 12's to mid 11's.
Boosted and sprayed trucks...low 12's to low 11's.
Anything lower is like a religious pilgrimage, be prepared for the most difficult challenge of your life...
Then there is FstJack's voyage...this is pure madness...but will probably result in a run in the 8 second range...by my estimate, by the time this is achieved it will entail three years of work, and will cost about $50,000 a second to move from a 12 second ET to an 8 second ET.
Choose your goal...have a ball in the pursuit, but you won't be alone if you fall a little short...there are lots of us who have tried and not quite reached nirvana.
