hotrodjim1
I really hate to do this....if you remove the front sway bar, loosen your front suspension up with urethane bushings and 90/10 shocks, when you launch the upward movement of the front end will transfer more weight to the rear than adding weight, and you don't have to carry the added weight all the way down the track. If you go farther and soften the rear springs and add Cal-tracs it just gets better. You may not need slicks just tire with a traction rating as close to 200 as possible, (what I did as a street racer in my youth..)
