Spark plugs have been around almost as long as the internal combustion engine. In 1902, spark plugs were first used with a high voltage magneto to provide reliable ignition. For the next 70 years, spark plugs were a high maintenance item thanks to tetraethyl lead, which was used as an octane-boosting additive in gasoline. Unfortunately, lead tended to foul spark plugs after 12,000 to 15,000 miles of driving. Consequently, tune-ups and spark plug changes were an annual ritual for most motorists.
Then came the Clean Air Act of 1970, followed by new emissions regulations and the introduction of catalytic converters in 1975. Leaded gasoline was gradually phased out because of its damaging effects on converters as well as the environment. As a result, spark plug life more than doubled.
In the mid-1980s, spark plug manufacturers started making plugs with copper core center electrodes. Copper is an excellent conductor of heat and allows plugs to run hotter without causing preignition. This improves fouling resistance, ignition reliability and plug life. It also reduces the number of plugs needed to cover a range of engine applications because each plug has a broader "heat range."
The biggest improvement in spark plug technology, though, came in 1985 when the first generation "long life" plugs with platinum or gold-palladium electrodes hit the market. Up to this point, electrode wear usually dictated when a set of plugs had to be replaced. With standard nickel alloy electrodes, the spark gap between the center and ground electrodes grows about .0002" to .0006" for every 1,000 miles of driving. After 35,000 miles of driving, the gap can grow as much as 0.015" or more.
Every time a spark plug fires, the hot spark blasts a few molecules of metal off the electrodes. As the miles add up, the electrode gap widens and the center electrode becomes rounded and dull. This increases the firing voltage needed to jump the gap. Eventually the point is reached where the ignition system can't generate enough juice to jump the gap, causing the plug to misfire.
With platinum, gold-palladium and other exotic metals (more on this in a minute), electrode wear is greatly reduced. Most platinum plugs can go up to 100,000 miles before they have to be replaced. The same is true for plugs that use other exotic metals such as iridium for their center electrode. Plugs with platinum on both electrodes ("double" platinum plugs) experience even less wear than plugs with only a single platinum or platinum-tipped electrode.
Long-life spark plugs drastically reduce the need for maintenance while helping the engine maintain like-new performance and emissions. Not having to change the plugs so often is a real savings for the vehicle owner, but it's no guarantee the plugs will go the distance.
Platinum & Iridium Spark Plugs
Long-life spark plugs by ACDelco, Autolite, Bosch, Champion, Denso,NGK, and Split-Fire all have platinum or platinum-tipped electrodes. With a couple of exceptions, most of these plugs use a conventional electrode configuration with a small platinum plug welded to the tip of one or both electrodes. ACDelco also offers a platinum version of its "Rapidfire" plug that features a fluted center electrode for improved ignition reliability. Likewise, Split-Fire offers a platinum version of its split electrode plugs for motorists who want extended life as well as reduced misfiring.
Bosch, who introduced the first platinum plug back in 1985, offers several different electrode configurations in their product line. Their standard platinum plug has a thin pure platinum center electrode with a single yttrium-alloy end electrode. Their Platinum+2 and Platinum+4 plugs, on the other hand, have a unique "surface gap" side electrode design with two side electrodes on the Platinum+2 plug and four on the Platinum+4 - a sort of good, better, best approach to platinum plug technology. Increasing the number of side electrodes gives the spark more paths to ground and reduces the risk of misfire, while extending plug life by spreading wear over more electrode surfaces.
In the fall of 2006, Bosch introduced yet another long-life spark plug called Platinum IR Fusion. Similar in design to the Platinum+4 plug, this new plug uses a center electrode made of a unique iridium/platinum alloy. The four side electrodes are a wear-resistant yttrium alloy. By combining platinum and iridium in the center electrode, Bosch says their new plug provides even longer service life (probably the longest of any spark plug that is currently available). Bosch also says their new Platinum IR Fusion plugs are an ideal replacement for any engine that comes originally equipped with either iridium spark plugs or platinum spark plugs.
One important point to keep in mind with respect to Bosch Platinum IR Fusion, Platinum+4 and Platinum+2 plugs is that these plugs are pre-gapped at the factory to a uniform 1.6 mm setting and should not be re-gapped to the specifications for a standard spark plug. It's very difficult to get even spacing with multiple electrodes so install them without changing the electrode gaps.
NGK "Iridium IX" and Denso brand "Iridium Power" plugs use a different exotic metal for their center electrode: you guessed it, iridium. Alloyed with rhodium, the iridium electrode is six times harder and eight times stronger than platinum. Pure iridium also has a melting temperature that is almost 1,200� F higher than platinum, making it a very tough metal indeed. On late-model Toyota and Lexus applications, the OEM-recommended replacement interval for Denso iridium plugs is 120,000 miles.
The iridium plugs also have a very thin (0.6 mm to 0.7 mm depending on the plug) center electrode. The end electrode has a "U-Groove" that improves ignition reliability and wear resistance. Denso says their design reduces the required firing voltage up to 5,000 volts compared to a standard spark plug.
For performance applications, Denso has also developed Iridium Power plugs with a super narrow 0.4 mm center electrode. These plugs are engineered to improve ignition reliability under extreme driving conditions rather than longevity, so the recommended replacement interval for the iridium plugs with the super narrow 0.4 mm center electrodes is 30,000 miles.
Here's another bit of trivia for the gray matter: Iridium is literally an out-of-this-world metal. Approximately 50 million years ago, according to the Denso website, a giant asteroid from outer space smashed into our planet near the Mexican town of Chicxulub in Yucatan. The impact created a firestorm and dust cloud that darkened the Earth for years, wiped out the dinosaurs and left us with a layer of iridium-rich deposits that is evenly spread across every continent (the "K/T boundary" layer).
Spark Plug Electrode Magic
Spark plug manufacturers tout the advantages of their unique electrode designs, but regardless of the design, the purpose is to make it as easy as possible for the plug to fire reliably. A spark jumps more easily from a sharp edge than a rounded blunt edge. So the more sharp edges it has to jump to, the better the odds of the plug firing under all types of driving conditions. The electrodes on some spark plugs are also designed to "unshroud" the spark so more of the spark will be exposed to the air/fuel mixture. This improves the propagation of the flame kernel once the fire is lit.
**********************One thing to keep in mind with respect to performance claims is that no spark plug creates horsepower out of thin air. A special electrode configuration can reduce misfiring and the voltage needed to fire the plugs. But the spark only ignites what is already in the combustion chamber. If there are any power gains to be had, they will be the result of reduced misfires and nothing else.*******************************
New Spark Plugs Getting Smaller
Another trend in the ongoing evolution of spark plugs is that plugs are shrinking. The new Ford Triton engines use long-reach 10 mm plugs from Autolite, which are 4 mm skinnier than the 14 mm plugs you're used to seeing in most late-model engines. The threads on these plugs are also 1-3/8" above the end of the plug, so heat has a long ways to travel before it can be dissipated through the threads into the cylinder head. This requires a couple of tricks to manage heat. One is an unusual "U" shaped end electrode that wraps all the way over the end of the plug. Connecting both ends of the electrode to the plug shell creates two paths for heat to flow away from the tip. The end electrode is made of a special high temperature Inconel alloy. In the center of the "U" is a small platinum pad to reduce electrode wear when the plug fires. The center electrode is also platinum tipped and has a copper core to help pull heat away from the tip.
Autolite is also marketing a new "Titanium" spark plug. It's actually a standard spark plug with platinum tipped electrodes, but with a special titanium coating on the shell that resists seizing to reduce the risk of thread damage when changing plugs in aluminum cylinder heads.
Spark Plug Fouling Resistance
One thing all types of spark plugs must do is resist fouling. The trick here is to keep the electrodes hot enough to burn off fouling deposits but not so hot that they cause preignition. To burn off carbon deposits, the center electrode needs to reach about 700 degrees F quickly. But if it gets too hot (above -1,500 degrees F depending on the plug design), it may ignite the fuel before the spark occurs, causing preignition and detonation. For most plugs, the ideal operating temperature is around 1,200 degrees F.
The temperature of the electrodes is controlled by the length of the ceramic insulator that surrounds the center electrode and the design of the electrode itself. Ceramics do not conduct heat very well, so an insulator with a relatively long nose will conduct heat away from the electrode more slowly than one with a relatively short nose. The longer the path between the electrode and the surrounding plug shell, the slower the rate of cooling and the hotter the plug.
A spark plug's "heat range" (heat rating), depends on the length of the ceramic insulator and the design of the center electrode. The heat range must be carefully matched to the engine application otherwise the plugs may experience fouling problems at idle or run too hot under load causing preignition and detonation. Most plugs today have a relatively broad heat range thanks to the copper core center electrode described earlier. This allows the plugs to reach a self-cleaning temperature quickly and also prevents them from overheating.
Spark Plug Misfires
The voltage required to produce a spark can range from as little as 5,000 volts to as much as 30,000 volts or higher. The actual firing voltage will vary depending on operating conditions such as engine load, rpm, temperature, compression and the richness or leanness of the air/fuel mixture. The wider the electrode gap and the greater the load on the engine, the more voltage it takes to fire the spark plugs. Likewise, the higher the resistance in the spark plugs and plug wires, the higher the required firing voltage.
A cylinder may misfire if the spark never reaches the plug due to excessive resistance or breaks in the insulation in the plug wires, or a buildup of oxide, cracks or an excessively wide air gap inside a distributor cap. A weak coil or a faulty ignition module that doesn't give the coil enough time to fully charge between firings also can reduce the available firing voltage to the point where the spark may be too weak to jump the electrode gap. Of course, worn or dirty spark plugs also can make an engine hard to start, idle roughly, lack smoothness, waste fuel and pollute, too.
The most common cause of ignition misfire at the spark plug is fouling. A buildup of fuel and oil residue or other contaminants on or around the plug's electrodes can short out the spark before it reaches the gap. Contaminants also can form a barrier that blocks the gap or requires more voltage to punch through than the ignition system can deliver. The contaminants come from fuel additives as well as oil that gets past the rings and valve guide seals. A high-mileage engine with worn rings, cylinders and/or valve guides will often have a plug fouling problem.
On 1995 and newer vehicles with OBD II, ignition misfire will usually set a fault code and turn on the Check Engine light. Fuel that isn't burned causes a huge increase in hydrocarbon emissions and will usually cause a vehicle to fail an emissions test. Unburned fuel also can damage the catalytic converter by causing it to overheat. So if you find a cylinder-specific misfire code such as P0302 (indicating cylinder #2), check the spark plug, plug wire, coil (if it's a DIS or coil-on-plug system), fuel injector and compression to isolate the cause. On the other hand, if you find a random misfire code (P0300), the problem probably is not the ignition system. It's likely a lean fuel mixture caused by a vacuum leak or dirty injectors.
